1/4 Elliptics- Getting the Bast__rd Apart
Jim_Gruber
One of Bugsy II's 1/4 Ell 2015 26 15 Spring IMG_1233.jpg2015 26 15 Spring IMG_1235.jpg2015 12 26  Spring IMG_1232.JPG2015 26 15 Spring IMG_1237.jpgiptics came out without a struggle from the Spring Box, everything is clean as a whistle. The PS on the other hand is a pig that I needed to drill out to extricate. I marinated in Evaporust for the past 4 days and pulled it out and placed in my trusty vice. A couple of sharp blows with my 5 lb sledge and a punch allowed me to remove/punch out the centering bolt fairly easily. Now I need to remove the two rear Spring Bolts. I needed to drill out the centers to remove the head of the bolt. Now I need some advice as how to get these the rest of the way apart and save the spring. The springs are usable and can be cleaned up if I can get this basta_d apart. Advice guys.
Have Drill press with machinist vice and could drill out but I fear I could end up drilling off center as I get through the stack. Other thought was getting the other end apart and somehow wedging spring apart from the two bolts that are rusted in place. Need some cogitation on next steps. Here are a few pics.
If I get my Dremel with a cutting Blade under the Spring Plate can I cut it and then Drive out the bolts after some more marinating in EvapoRust? Thinking that may be my next step.
Get the leaves apart, Sand, Etch, POR-15 - Black, Graphite Paste between leaves and then bolt back together.
Spring Bushing, Any easy way to extract, marinate the other end of the spring and then hacksaw blade to cut or put in a press.
Kudos again to EvapoRust for helping to get the centering bolt out.
Rut
Jim,
Use your angle grinder or sawzall to cut the head off and drive it thru. I sand blasted mine and primed with self etching primer followed by Slipplate. If I had to do it again I'd just blast and paint with Slipplate and go with the dark grey look. It preserves the springs and lubricates them so they won't squeak...since its dry it doesn't attract dirt and grit.
Rut
https://www.slipplate.com
Jim_Gruber
Jim_Gruber
Rut do you mean cut the Spring Plate head off of the nut slide. Since these bolts are threaded into the Spring Plate thinking that will become a sacrificial piece O may need to cut the top Spring Plate in half so I can drive out one side at a time.
Rut
Jim,
You will be replacing the 2 spring plates and the 2 bolts, so cut off whichever end is easiest. The only thing you want to save are the spring leaves and clamps...you will replace the bushings, spring plate, bolts, etc. You can wire brush or blast them in prep for paint/graphite...I even used a sander on the sides to clean up the pitting.
Rut
Jim_Gruber
Jim_Gruber
Sounds like a plan for tomorrow morning. And then if time allows a little spot weld cutting.
So anyone got a source for the small U Bolt Clamps that go on the spring leaves. I know they aren't in the VB Catalog, MOSS? AH Spares?
The_architect
Hi Jim. I did exactly what Rut said. Punch out the locating bolt. The spring plates should be replaced, and the bolts that hold them together as well. When I put mine back together I lined everything up and taped the spring plate in place so that I could get the bolts lined up through the bottom of the spring box.
The small clamps are just strap steel--they are fastened to the top leaves with a short stud that is peened into place but that's it. If you are going to replace those clamps you will have to make them. I replaced the bushings that the bolts at the bottom go through with some from the hardware store.
As far as the rear U-bolts and plates are concerned, I bought some Seachoice Square U-Bolts, 2-1/16" x 3 3/8" from Amazon--they are heavily galvanized, although the legs are too long and the amount that is threaded is too short. I just cut the threads longer with a die and cut them off to the appropriate length. I bought some 3/4 x 3/16 bar stock and made the clamping plates with it.
I could also not find the locating bolts with the correct rounded head, so I turned them on the lathe (any excuse to use the lathe! :fat: ).
I torched the spring eye bushings out. Makes a little smoke but once the rubber gets soft they push right out.
For finishing I used PB blaster to help loosen the and a wire brush in a hand grinder to clean them, although mine were not pitted at all, washed them in mineral spirits, and painted them with EZ Slide paint from Tractor Supply. I painted the bottoms, tops, and sides with black enamel.
Good luck--I was thrilled that the back end of the car doesn't squeak anymore!
Jim_Gruber
Jim_Gruber
Cool I'll check out those clamps. Thanks again.
Nelson
Jim you should check out the place I got most of my hardware from. It is The Bolt Depot. They have that size square u-bolts for $2.97 as compared to Amazon at 7.78. Almost all of my nuts, bolts and screws came from them.
Jim_Gruber
Jim_Gruber
Thanks Nelson. I also found that Frogeye Spares in UK has a bunch of the small fiddly bits needed.i'll check out Bolt Depot. Thanks.
Rut
Jim,
Make sure you buy the correct grade of fastener...the last thing you want is for a suspension or brake bolt to let go under stress. Whether it's necessary or not I like to move up a grade when possible so the ham fisted mechanic working on my car (me) has a little extra security.
Rut
Jim_Gruber
Jim_Gruber
Safety Fast!
The_architect
Jim--checked out Frogeye Spares when I was doing this, and thought £25 for a U-bolt was crazy. I got mine from Amazon $3.25 with two day delivery.
The locating pin they are showing looks more like a carriage bolt, which personally I don't think would work very well, and does not match the original design. But maybe what's in the photo is not what they are selling.
You will notice that the original that does two things. It holds the spring pack together when you shoving the pack in the springbox and
the cylindrical head on the bottom fits in a hole on in the springbox. When the pack is in the right place you shove the bolts through the bottom up through the spring pack, which is probably obvious. What might be missing here is that there is some horizontal play that makes this difficult--the springbox is somewhat wider than the spring pack--so if that cylindrical end doesn't drop in the hole you are not going to be able to locate it correctly.
Just my .02 cents. I just turned down the hex head of a grade 8 bolt for this. Took about five minutes. The nut, incidentally, fits between the slots of the spring plate.
Also i supported the back end of the spring with a floor jack when I was installing this.
Jim_Gruber
Jim_Gruber
Guys would something like this work for 1/4 Elliptics. I see two types of clamps which could replace the clamps that are on the spring presently. These come in 1 3/4" and 2" widths/ Spring appears to measure 1 7/8" so guessing a 2" clip would work or do I need to go to some sort of U Bolt Setup. I see two different types, those with a flat plate and nuts and those with a Horizontal Bolt that runs under the spring holding the sides together. Leaf Spring Clip Strap s-l400.jpg
The_architect
Jim--just to make sure we're clear--the U-bolt I am referring to is the one that clamps the spring in front of the bushing.
As far as using a u-bolt to replace the straps, it somehow needs to be fastened to the leaf spring, otherwise it will just slip off toward the rear. The spring clip you are showing is only 14 gauge--I am not sure that is thick enough.
Are your original straps badly rusted? If not I would just clean and reuse them. They are still fastened to the leaves, correct?
Jim_Gruber
Jim_Gruber
I'll take some pics of the clamps tomorrow. So much for best laid plans. Nothing got done to Bugsy today. 14 for dinner took priorities and I couldn't convince Colleen I just needed 30 minutes in the garage today. I'll take pics tomorrow night of the clamp.
Jim_Gruber
Jim_Gruber
2016 01 01 IMG_2625.jpg2016 01 01 IMG_2627.jpgA couple of more days for Spring in Evaporust. I used the angle grinder to cut the top of the Spring Plate Bolt off and flush with the top Spring mounting plate. With Spring firmly in vise. I was able to use a cold chisel and a 5 lb sledge against the lip that sticks out around the side of the top spring plate. A couple of good smacks on each side to keep things moving evenly and the spring plate began to move. Leaves began to separate as the bolts for the spring plate began to move past the leaves 1/4", 1/2", keep pounding, 1" and all of a sudden all the leaves were free. Yeah. Other spring is in Evaporust now to free up the centering bolt, a project for tomorrow morning.
This question was asked - "Are your original straps badly rusted? If not I would just clean and reuse them. They are still fastened to the leaves, correct?" In the two pics you can see the straps I am referring to. First Set Pic is of Spring I just took apart, 2nd pic is a set of 10 leaf Springs I acquired for a very good price but I don't want to use if I can find Clamps/Straps that hold the spring leaves together in the middle. Would a real Spring Shop have these type of banding clamps. Plan is to call Dayton Spring tomorrow if they are open and drop by to show them what I am looking for. If they sell or can restrap for a few bucks after painting and cleanup I'm good.
Next step get the other one apart after driving out the centering bolt. Use the heat wrench to remove/burn out the rear bushing, wire wheel everywhere, anti rust / POR-15, paint leaves with SlipPlate, reassemble with new straps, nuts, clean up U Bolts and see if they are salvageable, new set of Straps from Strapping Lab and new bumpers, bushings for Radius Arms.
On to the Rear End. Buddy has a 3.9 Pumpkin available which will go well with my 5 speed. Swap axles for a set on EN-17's in my garage. Swap in 3.9 pumpkin. Wire Wheel and clean up the rear end, New Rear Wheel Bearings, Thanks for the tip on the Subaru Sealed Bearings who ever posted, new seals, install upgraded backing plates to match 3/4" Master, Shoes, Wheel cylinders, Modify E-Brake Rod and have it ready as a bolt on sub - assembly.
All in a days work.
The_architect
Jim
Ok--here's the confusion. The clamps that you have pictured don't look like mine. Mine have a U-shaped piece of strap iron, maybe 3/16" by 1", that is riveted to the top leaf. The legs of the U run down the sides of the spring pack and are fastened together around the bottom leaf with a bolt. That bolt runs through a bushing that is simply a round tube that seems to have been formed out of sheet metal. I wish I had a photo--it must be on my computer at work.
So, I don't have an answer to your question--they must have changed the design at some point. Maybe someone else can help!
Jim_Gruber
Jim_Gruber
If you look at the pictures in MOSScatalog the original design is just as you described. Yes design was indeed changed. OK that resolves my confusion. Thinking if I take to a real spring shop they may be able to help. Looking on line I do see some design for spring retainers/clamps but they are not the correct width. It may be possible to fabricate a strap in the correct width but as someone commented the stuff I see commercially available is may from 14ga steel and may not be heavy enough. I'll keep looking and check out the Spring shop as well.thanks.
Rut
I wish I had a better picture than this, but I hope it helps.
Rut
The_architect
Thanks, Rut. Yes, mine are like yours, and the same as those shown in the Moss catalog. Sorry Jim, I wish I could be more helpful.
Jim_Gruber Bolts and Washers for 1/4 Elliptics Spridgets 2
Jim_Gruber Spring Clamps needed for 1/4 Elliptics Spridgets 38
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
J Finally getting (re) started on the Bugeye Spridgets 27
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
