GT6 Where have all the GT6s gone?
MedicMan55
Medicman again, ive been looking on ebay and a couple of other sites, and there are few if none on the site. Is this because of the nice weather and people driving them? Is it just a low point in the sale of GT6s? I would like to know.
Medic
sammyb
The problem with GT6s is that there are fewer relative to Spitfires, but they have similar low values and problems with trim parts that are not reproduced. Therefore, the low value makes them cost prohibitive to restore.
So many of the GT6s are rotting away under tarps. They do come up for sale, but the best place to find them is not on Ebay, but on regional sites, like Craigslist.com, collectorcartraderonline.com etc...
kindofblue
[ QUOTE ]
[/ QUOTE ]
You got that right. My friend has two of them, one restorable, one parts, sitting under tarps in NJ. I can't convince him to sell them, even though he hasn't done anything with them in years.
V
vagt6
I think it's been that way with GT6s for many years. It's always difficult to find a nice example.
But, nice ones are out there for sale. Timing is everything, you simply have to keep at it, monitoring all the sales venues until you find the right one.
It took me almost a year to find my last GT6, and it was worth the wait.
BTW, if you'll let us know what you're looking for, maybe someone here could alert you if one surfaces?
Good luck, wait for the "right" one!
sammyb
Mark is absolutely right...it is all about timing, which means the more places you look, the better chance you have at finding one.
It is not uncommon to spend one or two years looking for the right LBC.
Geo Hahn
Here's a theory for which I have no supporting empirical evidence: GT6s seem to have been more popular in the East & Northeast as compared to the West & Southwest due perhaps to the weather. Thus, in addition to fewer being built, they may have a higher mortality rate from rust.
MDCanaday
I think that if there EVER were any loyal gt6 owners ,they were baked alive long ago on the first hot day of summer.How these cars were ever sold without sunroofs(as the period VWs had) is more than I can fathom.
MD(mad dog)
Bugeye58
The Webasto sunroof was an option on the GT6. After the MkI, the later ones had improved ventilation, but it never did entirely solve the problem. Of course, mine is an early MkI, with absolutely no ventilation. One of these days I'll get it finished, and play shake & bake.
A friend of mine used to work for a Ferrari/Triumph dealer, and she told me that the GT6 was the hottest car she had ever driven in her life.
Jeff
TR_Jim
I spent a lot of time sealing up my GT6 and now it's fairly comfortable, even on hot summer days. I used that heat/sound deadening material to line the inside of the trans tunnel and the floor boards. I also added an extra seal when mounting the tunnel. I'd recommend using that heat/sound deadening material...it really helps.
Bugeye58
But, Jim, you have those zoomie little dash vents, and the extra vents in the bonnet and rear quarter panel, don't you?
I've got squat in the MkI. I've got the aluminum mat slated for installation, as well as a firewall blanket, and extra sealing planned for around the tunnel.
I don't plan on driving the thing all that much when the weather is unbearable anyway. That's what all my topless cars are for.
Jeff
V
vagt6
Too hot in your GT6??? No problemo!!!
Just open up the rear hatch and go! /ubbthreads/images/graemlins/crazyeyes.gif
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
