MGB Anyone have experience with the Pertronix Ignitor III?
max71
As the points I love are getting harder and harder to find I was wondering if anyone has experience with the new Ignitor III for a 25D?
One time a mechanic tried to fit the original version to my car and couldn't get it to work. On all the runs I've been on the only cars that dropped dead all had electronic ignition. Of course all modern cars have this but we're doing retro fits.
I was warned that with the III I would have to get a Flamethrower III coil due to low impedance and heavier demand.
Sopwith_Camel
I ran one in Snoopy (72 spridget) for years and it solved starting issues. put one in the jag but on installing it found the distributer body had holes so I had to replace the whole distributer, so no real good data there.
MustangSix
I have had an Ignitor II on my B GT for several years. No issues; starts on the key every time. I use the stock Lucas coil.
You should be able use any coil with the Pertronix III if the impedance is greater than 0.32 ohms.
Sarastro
The Pertronix III comes with a warning that you have to use resistor plug wire to prevent electromagnetic interference problems, and from what I've heard, that's for real.
Frankly, I wonder if the advantages of that unit, compared to the original Ignitor, are significant for our cars. I doubt that you'd be able to tell the difference. As for reliability, electronic components at their worst are better than mechanical or electromechanical ones at their best. Virtually all of the ignition problems I deal with involve points, not electronic ignitions.
Also, remember that Pertronix is not the best or only option. There are lots of electronic ignition systems available. I use a 123Ignition distributor in my Porsche 912, and I like it a lot. I used a Crane in my Bugeye, and it was fine.
max71
max71
I was told by BPNorthwest that as long as you do not use solid core wires and get the Pertronix coil (very low resistance for multiple spark) you're fine and they sell and have a good history with them. I was never sold on Pertronix. The very first one was just jerry-rigged for the B. It was actually made for fork lifts. The II was better. The III if it has multiple spark is a compact MSD.
I was hot for the 123 but I thought that was British? Or was that the Luminar? I guess that's why I'm looking for feedback. Appreciate yours, Steve!
MustangSix
Another alternative would be to retain the points and use them to trigger an MSD or other such box. I have that setup in my MGC using the Streetfire version of the MSD box with a Ford E-core coil. The MGC used to be a little "lazy" when cold, but now is very responsive and starts easily with a good steady idle. I had to use a tach adapter to operate the current driven tach on that car.
Some would argue that a well tuned set of points should perform the same, but that's never been true of my particular car. The massive whack of a multiple spark across a .055" gap lights the fire far more effectively. You have to ensure the rotor, cap, and wires are up to snuff to prevent crossfires. And the points should last darn near forever since there's no longer any significant current flowing thru them and the point gap is irrelevant to its operation.
max71
max71
Very interesting. I tried MSD + the tach accessory because it wouldn't trigger my tach. Maybe I used the wrong gap on the plugs but I didn't experience a big difference. I eventually sold them.
GTP1960
I run a Pertronix III in my TR3A.
initially I had problems, not with the P III, but with the accompanying flamethrower III coil.
Of course it took me quite awhile to pin down the problem.
the FIII coil was great for starting & offering more pep, but after it warmed up, (45 min or so) she would start missing & running rough. Went back to a Flamethrower II & no more problems ( but doesn't start as well).
max71
max71
That's incredibly interesting. BP Northwest said I would have to get a FIII to make it work. I use Lucas Sport Coils now which they said wasn't suited. It would also be incredibly disappointing as I'm reticent to go to EI. How long ago was that? I wonder if they fixed the problem or its a factor of a LBC.
That would really suck to go through all this and duplicate your finding. :welcoming:
GTP1960
Actually, I went back to my Lucas sport coil when I dumped the FIII. It worked fine. ( easier starts than the current FII, but not quite as much operating pep [can not say why]). I switched to the FII strictly to standardize to Pertronix, for better or worse. ( keeping my Lucas as trunk back up). Also switched out my cobalt wires to pertronix wires.
This has all been in the past three or four months. I bought the PIII/FIII system from summit I think, and never circled back.
BTW: I have a # of blog entries about the whole sordid affair, if interested, but you'll have to scroll back.
best regards,
Guy
max71
max71
Guy - what I was told and it makes sense is that the FIII has a very low impedance hence it can create the multiple spark of the PIII. I would really like to read your blog if you can post it. Much appreciated.
GTP1960
I don't know much about backward compatibility with the PIII. But I believe the PIII will work with most coils.
but, on the other hand I think the Flamethrower III coil might not be compatible with earlier ignition systems, though I never tried it with my earlier pertronix ignition.
as for my blog, I just post to the one on this website ( see "Blogs") in the primary menu line at the top of this page.
i just keep a running journal on my progress (have found it helps keep me energized for the next project!) . The blog feature here is underutilized, so my entry's are predominant.
M Anyone Have Experience with Moto Build Ashley or Speedwell Repro Hardtops? Spridgets 2
W Anyone had experience with this vendor? Spridgets 8
K Anyone experience a broken crosshaft pin.... Triumph 6
justin_mercier Anyone have experience w Dayton bolt-on wire wheel Triumph 3
Gliderman8 Anyone experience this.....? Austin Healey 6
UmmYeahOk Anyone have any experience with this company? Triumph 6
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 26
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
