Electrical tach issue on Aston Martin DB5
busybrit
I'm hoping someone can help me with my electrical gremlin.
I'm working on a 1965 DB5 and both the fuel gauge and the rev counter work fine, but the flashers and handbrake warning light do not.
When I move the flasher arm to the on position, "up or down," or pull up on the handbrake, the rev counter drops to zero and the fuel gauge to fall to empty.
When I take off the handbrake or put the flasher arm in the middle "off" position both the rev counter and fuel gauge do not come back on.
However, if I turn off the ignition, then restart the car, both the fuel gauge and the rev counter now work,,, until I move the flasher arm or handbrake!
Any ideas????
Platinum
Sounds to me as if you have a grounding issue someplace in the flasher or handbrake warning lamp circuits (if it HAS a handbrake warning lamp!). My experience with David Brown's cars is limited to a DB2/4 drophead, so well before the example you're dealing with.
busybrit
busybrit
Problem solved, thought I'd let you know what it was. The flashers, handbrake warning light, fuel gauge and tach, all on the same circuit.
When the flashers or the handbrake warning light was activated the bulb/s called for more amps than the circuit was able to supply due to having a loose connection. The power draw resulted in sharing the reduced amps that was available, thus shutting down the whole circuit.
Thx Johnb
D Coil and/or Tach Electrical Problem MG 8
Ohiobugeye Tach Electrical Connections Spridgets 18
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
