Side exhaust, which muffler?
Steve P.
Work is progressing really well and amazingly fast on the '73 Midget I bought
a couple of weeks ago. While the existing exhaust system is still intact, not
so sure how long it'll stay that way so I'm considering alternatives. The one I
like best is a side exhaust just in front of the left, rear tire. And I will be using
headers too. This car is being built as a weekend warrior/occasional racer s
don't mind the racket.
Has anyone tried this and if so what did you use for a muffler? Not much room
under these things!
Steve
JPSmit
Motorcycle can?
I might try it without a muffler and use a baffle insert.
Truthfully there is no place for a muffler but the stock location. You do not need the dual box, you can use the straight out the back early style.
Branson
under these things!
Steve
How about this:
attachment.php
I thought about dumping the exhaust just before the rear wheel on my sprite but had the same concern regarding space. Im running a 12a rotary though so squeezing a decent sized muffler under the car is not likely going to happen. Guess I will have to route it out the back of the car like everyone else.
Steve P.
Steve P.
Thanks for the suggestions guys! Hadn't considered using a motorcycle muff.
I like it and in fact there is a Spridget in the area that uses one (rear mounted). Doesn't sound
like a side exhaust is practical but I will try to mock up something with what I have
available. Will post the results. Just crammed the headers in the engine bay and the outlet
is 2" dia. Bigger than M/C muffs I've seen.
The next Spridget I build will be a radical engine swap (RX7 or Lotus 907) so I'm
thinking about this as I build this mostly stock car. Hope to get together with some
of you guys that have gone down this road.
Steve
JPSmit
I am wondering about the space behind the front wheel well - and next to the battery - inside the front fender - where I drop parts when working on the clutch - is there enough space for a top entry, bottom exit or bottom entry top exit?
Steve P.
Steve P.
Possibly. But you'd have to run the pipe up and over, then down to do this. Another thing I'm
looking into is called a 'baffle pipe' which is often used on M/C's. Its just a straight pipe
with some baffles inside. About as small as you can get and I've heard they work quite well
with a minimum of back pressure.
Steve
Walter74 AH Spares Side Exhaust Austin Healey 2
S Side exhaust system for BJ8 Austin Healey 16
Martinld123 Side exhaust for 1965 BN2 LHD car Austin Healey 14
J Side exhaust heat shield Austin Healey 23
E Got the side exit exhaust installed on my Austin Healey-Video Austin Healey 21
J Side Exit 1960's Style Exhaust on my BJ8 Austin Healey 23
bighealeysource Anyone ever mount a side exhaust on a BN1 or BN2 Austin Healey 16
T BJ7 Side Exhaust for increased clearance Austin Healey 19
cjm Side exiting exhaust pics plz. Triumph 2
Velox Side Exhaust Austin Healey 12
M Side versus rear exhaust Austin Healey 24
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
HealeyRick BJ7 Side Window Alignment Austin Healey 31
Fanch00 Noisy Side Screens Austin Healey 13
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
madhouse 100-Six Side Curtains Austin Healey 8
R MGA MGA Headrest fairing for R/H side MG 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
S TR2/3/3A foot well driver side carpet Triumph 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR2/3/3A tr3 side curtains Triumph 4
Healey Nut Side Screens Austin Healey 12
R Wanted 100 side curtains Austin Healey Classifieds 9
C MGA Side curtain info MG 11
