Early BN4 Seat Covers
RichsBN4
I am going to replace my seat covers on an EARLY BN4. Back in the 80’s the seat pans (but not backs) were replaced with used ones of unknown Healey year.
My question: What is the difference between EARLY BN4 seat covers compared to the late BN4’s and 3000’s.
Thanks,
Rich
57BN4
healeyblue
Heres a BN4. Seat cushion base is wood, 3000 cushion bases were steel. The main difference in appearance with BN4's is the seat back piping runs around the ear of the seat instead of cutting across the ear to the back.
CessnaTPA
I understand the difference between the early BN4-BN1 seat covers piping is different but physically are they the same? Will seat covers from a BN1 fit a BJ7 and vise versa?
Here is my dilemma, I ordered new seat covers and wooden seat bases for my longbridge BN4 and now realize I have the newer style metal seat bases and frames. Did I screw up and need to return everything?
John Turney
I'm sure the early BN4 seat covers and wooden bases will fit in the newer metal frames. The backs are identical, but the BN4 adds a wooden tack rail to the lower back.
healeyblue
I agree, they should fit. You could add the tack strip to the bottom and make them like the earlier style. The set bases are different in appearance but should still function the same. Be sure to wrap the frames in vinyl like the longbridge cars as well.
Jim
lewmac
CessnaTPA, do you have the lower profile Longbridge metal bases that the wood frames sit in, as shown in the above post by healeyblue? I believe with the later bases, the cushion just sits within the metal base, and the whole thing is covered with the leather or vinyl, without the wood frame, and then it sits within the frame shown in your post. Those tabs at the back are where the back of the metal seat base clips under and pushes back, in an attempt to keep the set base in place. This is the same approach used on Bugeyes and Mk2 Sprites / Mk1 Midgets . As healeyblue shows, the early metal pans can bolt directly to the floor on the passenger side or to the slider rails on the drivers side. On my early #750 Longbridge BN4, I had sliders on both sides and these were also mounted on cedar rails to lift off the carpet and allow the sliders to work. The seat bases were trashed so I bought later model repro seat bases and then found on eBay a good set or early metal bases as well, so need to decide which to use.
Cheers
Lew
lewmac
CessnaTPA, where did you get the wood frames from ? I think the seat covers will work for either, but you will only need the wood frame with the earlier metal bases, which are lower profile that the later metal bases. Thanks
Lew
CessnaTPA
Lew
No I don't have the seat frames like Healey Blue. I got the wooden seat bases from Moss. I'm going to call Moss tomorrow and verify their BN1 seat kit will fit the newer metal bases. If so I will return the wooden bases and reuse the metal ones I currently have. They have a lot of surface rust but I think they will cleanup. Hindsight I shouldn't have just placed the order based on the VIN number. Thanks for the help.
andrea
I am going to replace my seat covers on an EARLY BN4.....
Thanks,
Rich
57BN4
In My restoration of one early BN4 1957 -I followed DerekJ-site photos and considerations-for the rebuild works I followed the works of BORAS shop
in this album you can find some interesting foto collect for the rebuilding
https://goo.gl/photos/GHtf9JbRWCjKZWJw6
CessnaTPA
Thanks guys for the feedback. I've decided to return the wooden seat bases and exchange the front seat kit for the later BN4 version since I already have the later seat frames and bases in good condition. After talking to Moss they couldn't confirm if their BN1,BN2 early BN4 seat kits would fit the newer type seat bases.
I know it's not going to look original but I don't want to replace (spend $660 more) perfectly good seat frames & bases just for minor appearance changes that 99% of people won't even notice.
B Side window question for early Longbridge BN4 Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
Csarneson Early BN4 steering box pitting Austin Healey 16
K Correct side screen nut for early 58 BN4 Austin Healey 14
L Need a early BN4 hood bow Austin Healey 1
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Csarneson Early bn4 dipstick tube removal Austin Healey 7
B Source for Brake Tank Assembly for early BN4?? Austin Healey 4
V Early BN4 top vs. Later BN4 top,... Austin Healey 2
V early BN4 question - top & header rail Austin Healey 3
andrea EARLY BN4 STEERING BOX washers belleville Austin Healey 6
H Early Longbridge BN4 Tool Bag Austin Healey 3
andrea WIRING DIAGRAM for imprved BN4 100/6 and early BN7 Austin Healey 3
5 Headers for BN4/early 3000 Austin Healey 10
M BN4 [early] Toneau bar Austin Healey 4
ronzet Looking for pictures... Early BN4 interior Austin Healey 13
H 3 ltr engine BN4 to early BJ8 - dipstick markings Austin Healey 8
M Early BN4 tach cable routing Austin Healey 0
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
