Results 1 to 9 of 9
Thread: Oil Pump Grief
  1. #1
    Join Date
    Oct 2013
    Location
    Wellington, FL
    Posts
    150
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Oil Pump Grief
    Due to aggravating circumstances early in the rebuild my original pump was lost. I have heard the horror stories concerning the "County" or reproduction TR3/4 pumps and I guess there is only the one production source which all of the vendors use. One would think that one of the big outfits would have had a decent one produced by now. Of course if one asks a vendor they say that the pumps work OK. Has anyone had good experience in recent years with these repro pumps?
    Concerning originals, my first attempt at obtaining a decent item resulted in this:
    I haven't checked clearances yet. Does that look like excessive wear?
    Walter
    1974 Triumph TR6 (Previous)
    1959 Triumph TR3A, TS52910L (coming back together)
  2. #2
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,534
    Thanks Thanks Given
    3
    Thanked in
    Re: Oil Pump Grief
    You might want to consider sending that pump to British Frame & Engine. He will "clearance" the pump and will supply rotors (at an extra cost) if necessary. He get's about $70 for the job and of course extra if it needs the rotor and vane. All told it would still probably be less then the cost of a new pump from Moss. Looks like you'll have to send him an email (address on his site), as he no longer has a phone number listed. I sent my original pump to Ken and had it re-done as when I was doing my engine was during the period of the bad pumps, which I believe was a problem with the pin securing the rotor to the shaft.
    https://www.britishframeandengine.com/parts1.html
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  3. #3
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    5,087
    Thanks Thanks Given
    4
    19
    Thanked in
    Re: Oil Pump Grief
    I can't tell what I'm looking at in the right hand photo. Is that a chunk missing or discoloration? On the left pic, is there a distinct ridge on the right side of the rotor pads?
    If the answer to either of my questions is yes...then there is excess wear. If no to both...I can walk you through clearancing the pump.
    John
    1955 TR2
  4. #4
    Jedi Knight Brinkerhoff's Avatar
    Join Date
    Dec 2010
    Location
    Traverse City MI. USA
    Posts
    1,176
    Thanks Thanks Given
    6
    Thanked in
    Re: Oil Pump Grief
    Check the clearances with feeler gauges. If it measures ok I'd use it without hesitation.
  5. #5
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,099
    Thanks Thanks Given
    17
    Thanked in
    Re: Oil Pump Grief
    I would say that pump is toast. It looks like 2 views of the same pump, but one without the chunks missing? Try contacting Marv on the forum. He has a lot of used parts. Many of the old pumps are re-useable because they had an easy life being dipped in oil. It looks like the pump you acquired there came from an engine that had chunks of metal in it. Some of the people on evil bay also have extra parts when they show something, so you could contact the seller and ask. Good luck
  6. #6
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,870
    Thanks Thanks Given
    3
    Thanked in
    Re: Oil Pump Grief
    If you are investing in a pump, consider Steve Yott's redesign - racers love it, bulletproof.
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
  7. #7
    Join Date
    Dec 2010
    Location
    Posts
    1,176
    Thanks Thanks Given
    6
    Thanked in
    Re: Oil Pump Grief
    A visual exam isn't enough , it needs to be checked with feeler gauges per the shop manual. I've used them many times over with zero problems.
  8. #8
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,989
    Thanks Thanks Given
    4
    72
    Thanked in
    Re: Oil Pump Grief
    Quote Originally Posted by Brinkerhoff View Post
    I agree, but I think those photos tell the story. Time for either another original pump, or new rotors. Either way, be sure to check clearances before trying to run it. Many housings have been shortened slightly, to compensate for wear in the rotors (as described in the workshop manual).
    +1 on Steve Yott's unit, but they aren't cheap. Cheap enough I suppose, if you're protecting a $10,000 motor, but likely overkill for the street.
    Randall
  9. #9
    Join Date
    Oct 2013
    Location
    Wellington, FL
    Posts
    150
    Thanks Thanks Given
    Thanked in
    Re: Oil Pump Grief
    Thanks to all for your input. It is all very helpful. More based on what was not said, I am guessing that most of you are not big fans of the reproduction pump currently available...as long as the old ones last. Steve Yott's version is very interesting.
    Regards,
    Walter
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
