Bugeye transmission sticks in neutral
Rakos
Hi,
At a long traffic light I sometimes put the car in neutral and let the clutch out to relax.
Sometimes (maybe 25% of time) I can not get it into first.
I have to give it a real yank into second then it slides into first ok.
Could it be clutch? Have not bled clutch lines lately, seems difficult to get at the bleeder.
John
JPSmit
Could be, but don't forget, there is no synchro on first gear - so, second to first would be a normal pattern anyways wouldn't it?
Keith_M
This happens to me all the time, and I assume it's because the gear teeth don't line up right when the input shaft stops spinning. Pulling the gearshift into second moves the gears enough that they line up. The other "fix" for this is to shift into first before the input shaft completely stops spinning. If you time it right, the gears will mesh but not grind.
By the way, putting the car in neutral and letting the clutch out while stopped is a good idea; it will save your throwout bearing. I do it routinely if I'm going to be stopped for more than a few seconds.
Bayless
I try to do that with the Beetle all the time. SWMBO complains and doesn't want to comply so I remind her that she is not the one who has to change that TO bearing.
SD Bugeye
Smooth case? Buyeye
i would say change oil and make sure to not use a gear lube engine oil only
clutch maybe but it's hydro so not likely.
Could be worn carbon ...
SaxMan
I have trouble catching 1st periodically in my '69 Sprite. Scared the crap out of me the first time I experienced it. I thought I had garbaged the tranny. I can usually get it to go if I use a little bit of force or if the car moves just enough to get the teeth to line up. I was afraid of mashing the teeth, but when I changed the tranny oil, it was the same color that it was when I put it in, with no metal.
Funny thing is, I always put the car in the neutral and let the clutch out when stopped. That's just what I did when I first learned to drive stick. I will sometimes stand on the clutch and put it in gear when the light is about to turn green, just so I know that I have the gear. I also have been able to catch 1st while moving slowly without mashing any gears.
M What is the proper oil for Bugeye engne and transmission Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
I Bugeye transmission options? Spridgets 11
A Bugeye transmission Spridgets 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
