I have fixed some electrical faults now. I got the panel lights working! Wooha! But now my problem is the rear left turn signal. I have a 3000 -64 phase 2, with no separate turn signal. The right side works like a charm. On the left side only the front turn signal works. From what I have read on the forums it seems that the turn signals have two different relays that are important (correct me if I completely have misunderstood this). I have checked the rear left for voltage and it seems that it goes up and down when I have the signal for turning left swithed on, but it seems so be very low power. I also checked the power on the turn switch and it swithes power correctly. I have checked the flasher unit and I'm really not sure here. It seems strange that there are three wires going to just two pins (when there actually 3 pins on the flasher) one is separate, and two are together connected to one. See pic.
I also tried to measure the turn signal relay (if I understand this correctly this is the thing that distributes the signals to the right lights - I'm soo lost at this, sorry). When I measured the blue marked pin, it at some point stopped the relay and it started to actually burn underneath it, just very small. Must have been som kind of short end. Well, now I'm a bit afraid to measure again. This happened when I had the turn signal to the right - which is the side that works on the car.
Anyone have a clue what is wrong here?
Danne
Danne
