Turn signal wiring on back of switch. What goes where.
jaegzie
Ok I feel like it should be relatively simple but my issue is hooking up the switch. I can run a hot wire to each of the turn signals where they meet at the switch and they both blink as they should. When I hook up the switch nothing.
Can an anyone tell me which wire goes to which terminal. I have tried 4 switches and unless all of them are bad I'm hooking it wrong. I would just pull and try on different terminals but I don't feel like burning anything out.
This is a 3 terminal switch.
Thanks, mike
and a pic of my project it's been a long time.
nomad
I may have forgotten but aren't the turn signal's on a BE supposed to be the small round bee hive light's?? A cheap VOM meter would quickly solve the switch wiring problem.
Kurt.
jaegzie
jaegzie
Here is the pic of the switch. Just wondering which wire goes where.
i would assume signal are 2/8 and power is 7 but I really don't want to burn out anything if I hookup wrong.
I am not very good with wiring and kind of learning as I go.
Thanks.
smaceng
Mike, if you don't have a volt ohmmeter, you should get one.....or just a simple continuity tester. A continuity tester lights a light or buzzer when two leads are touched together. With your continuity tester there are three possibilities.
8 & 7
2 & 8
7 & 2
Test all three with the handle in the right position. The test that does light the light or buzz; these two connections go between one of the lamps and the flasher unit. Now switch the handle to the left position. Again the test that lights the light or buzzes is the other connection between the lamps and the flasher unit. Now, whichever terminal is common to both is the one which connects to the flasher unit, and the other two connect to the lamps. Hope my lesson here can give you some help to understand electricity a little better.
cheers,
Scott
R Spitfire Turn signal wiring Spitfire Triumph 5
R TR2/3/3A Turn signal wiring Triumph 1
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
apbos Turn Signal Wiring Problems Spridgets 3
T XKE Series 2 Turn Signal Lever Stalk Wiring Jaguar 5
Jim_Gruber 68 Spridget - Turn Signal Wiring Colors Spridgets 2
Woodie turn signal buzzer wiring Spridgets 17
Cain Turn signal wiring Triumph 20
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
