TR2/3/3A Capillary Tube Clips
Tropical TR
Anyone know if some insulating material should be wrapped underneath the clips when securing the temp gauge capillary to the fuel line? Have seen photos like this that look like folks have done it:
Regards,
Walter
mallard
Yes it should, I used black friction tape, kind of a cloth tape.
TomMull
I believe the friction tape was also used at factory. Tom
T
Tropical TR
Thanks, gentlemen. Just what I needed to know...and one doesn't see such things in the parts books. Appreciate it.
Regards,
Walter
D Capillary Oil Tube Fastener Austin Healey 5
M Capillary Tube repair Spridgets 4
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
R Capillary tube temp gauge Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
woolfman General MG Replacing capillary tube MG 10
B Temp gauge capillary tube Austin Healey 3
S Temp gauge capillary tube Austin Healey 8
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
martx-5 TR2/3/3A TR3 Capillary Tube Clamps Triumph 16
R Temperature capillary tube removal Austin Healey 10
M BN4 Capillary tube attaching Austin Healey 2
CharlieCarpenter What tool to use to disconnect capillary tube Austin Healey 6
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
C Capillary pipe clip Austin Healey 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
P MGB Tube axle wear MG 3
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
