What is the purpose of the brown wire on this steering rack?
Whitephrog
Keith_M
Probably an attempt to make sure the steering column is grounded so the horn will work.
I think this is right. I seem to remember a wire from the steering column to the frame. I think this is just misplaced.
Keith
nomad
Actually, there is a packing between the rack and the clamp that the ground wire attempt's to get around. Making the horn's work can be difficult. My 65 had a steel cable to ground that wrapped around the steering shaft when you turned. Appeared to be factory installed.
Kurt.
Rut
Kurt.
With the steering rack electrically isolated by the packing between the rack tube and its mounts, this was their attempt to ground it for the horn. I painted my rack mount brackets and effectively insulated it and the horn didn't work.
Rut
dklawson
It may be a brown wire but for commonality with Lucas color codes it should be "black". As stated above, they are fitted to some non BMC cars (especially Triumphs) to make sure the horn circuit has a path to ground through the pinion on the steering column and the rack housing. On TRs there is typically a black wire from the front wiring harness that attaches to the rack with the other end connected to the chassis somewhere.
W
Whitephrog
This horn grounding thing my be the root of all my electrical issues with the Whitephrog. It wasn't unusual for the horn to operate for no reason at all. I seem to recall the horn sounding occasionally when the headlamps were turned on. I believe that all this may have fried the ignition switch.
nomad
I believe that brown is supposed to be unfused hot. I'd have picked black, Doug.:chuncky: Unfused brown for the horn button circuit. Black after that.
Kurt.
smaceng
So I had the same problem that others had....horn would not work. Maybe I was wrong, but I insulated with fish paper the rack from the frame mounts as the factory specification. I can understand why the factory did this as the rack is steel and the mounts are aluminum. I do not think there is a good ground through the tie rods...may be they are rubber insulated? So I did what is suggested, I added the wire from the rack to the bolt which attaches the rack to the frame. What I want to know....how in the world did the factory get the horn to work reliably ????? As designed it is hit or miss.....as other have indicated.....as well as myself!
Any input would be appreciated. I think this is one of the only areas on my "old" 60FROG that I had to modify the factory design to make the car "operatehorn grounding.jpg."
Scott in CA
PAUL161
Not sure on Sprites, but Black is a Lucas standard for ground/earth. Brown is an, I think, unfused hot wire, with or without stripes. After all these years, who knows what's been changed on these cars. PJ
Bayless
That's right. Brown is unfused hot and ground is black. Of course who knows what some DPO may have added.
G
I'll have to check but I'd swear all of my lights are grounded brown on my 79 and it's an original unmolested harness.
nomad
Any input would be appreciated. I think this is one of the only areas on my "old" 60FROG that I had to modify the factory design to make the car "operateView attachment 36279."
Scott in CA
Scott, my 65 Midget had a small steel cable that attached at the steering shaft to rack pinion pinch bolt and went to the rack clamp frame attachment bolt. As you turned the wheel the cable would wrap around the steering shaft. Sure looked to be factory original.
Kurt.
Sarastro
I've always seen black for grounds on LBCs. However, for what it's worth, Bosch created a standard for wire colors, which is used in my '67 Porsche, and I suspect most or all other German cars. Maybe other European ones too. In that standard, brown is ground. So, it's not a great surprise that someone might be accustomed to that standard and just automatically used brown for a ground.
jlaird
After looking at the pic several times, I think it is a trick question. LOL
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
Walter74 Unknown Hole Purpose Austin Healey 2
nichola TR6 Re-purpose alert Triumph 0
Sarastro TR4/4A What's the purpose of this door part? Triumph 9
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
T TR2/3/3A What is the purpose of the groove behind TR3A door ? Triumph 6
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
brgrmyster GT6 GT6 Engine Mount "Spacers" - What's the Purpose? Triumph 2
J What's the purpose of the dust cap? Spridgets 7
L What is the purpose . . . Triumph 4
T the purpose of clubs Austin Healey 1
G Rebound Strap - What is its' purpose? Spridgets 9
D General Purpose Cleaning Restoration & Tools 1
C For Sale Brown Ebony Shift Knob Other British Classifieds 0
Healey Nut "Father Brown" British television series Austin Healey 9
Sopwith_Camel was this wire brown in 1967? Jaguar 5
Got_All_4 Wedge Brown carpet kit from britiish victoria Triumph 6
D The name is GT, Speedback GT [David Brown Speedback GT] Other British Cars 2
Sarastro T-Series MG TD on Father Brown MG 3
matttnz TR6 Brown wires multiplying Triumph 12
Got_All_4 Wedge Saw the yucky Brown TR7 today Triumph 5
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
L What is that brown blob??? FORUM Navigation Questions 7
mrsprite Oh yeah.....look what brown did for me! Spridgets 6
V Who's going Brown's Island show in Richmond? Triumph 2
S ALtenator brown wire Triumph 7
S alternator questions [ the brown wire has voltage Triumph 5
Sopwith_Camel the brown wire or the brown wire or the brown wire Spridgets 2
tosoutherncars What can Brown do for you? [TM] Spridgets 9
NutmegCT TR2/3/3A brown spatter after driving - TR3A Triumph 17
bugimike Duh! what's the brown stuff? Spridgets 7
B Brown's Lane Jaguar 5
blacknite3 Heater is in, antifreeze is brown and oil is thin! MG 7
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
