Results 1 to 3 of 3
Thread: Header Rail Assembly
  1. #1
    Join Date
    Nov 2009
    Location
    Steamboat Springs,Co.
    Posts
    232
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    About to put the header rail onto the frame.
    Is the correct method sliding the rubber seal thru the channels prior
    to riveting onto the frame ? Working from the center channel outward.
    Any other secrets ?
    Thanks everyone
    Harry
  2. #2
    Luke Skywalker trrdster2000's Avatar
    Join Date
    Sep 2004
    Location
    Salisbury NC
    Posts
    1,820
    Thanks Thanks Given
    12
    9
    Thanked in
    Re: Header Rail Assembly
    Harry, Pop rivet the channels on first and then just stuff the rubber seal in with a spatula that you use for putting body putty on and cut it too a couple of inches, it makes it easy with a little Vaseline on the rubber.
    Wayne
    '37 MG TA, '49 Triumph Roadster, '70 TR6, 2000 Jaguar XK8, '78 Spit6
  3. #3
    Join Date
    Nov 2009
    Location
    Posts
    232
    Thanks Thanks Given
    Thanked in
    Thanks for the reply Wayne. Forgot to ask which side of the rubber goes outwards . The short side?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
