Brake Actuators - anyone know about them?
JPSmit
So Friends, I have two currently soaking in weasel pee (acetone & ATF) from the Vauxhall
how do I get the guts out and is there a rebuild kit? These are Girling brakes if that matters
thanks all!
LarryK
Have you tried plugging all holes except ends after packing with grease and tapping carefully with a brass punch or air pressure? Just a thought.
JPSmit
JPSmit
:winner1:
Thank you for this suggestion - that is exactly what I needed to do - didn't even need to pack with grease or anything. What had perplexed me was that the pistons had slots in them suggesting that they were threaded. They weren't. So, I got out the screwdriver and a hammer and, sure enough it popped right out. (Only one of the castings though - but, that was all I needed)
Popped them out, cleaned them up, remarkably the rubbers were still in excellent shape as was the shaft. so, a good clean, lube and, Bob's your uncle.
Here is a before (sort of - the one that was seized) and the cleaned up one. About 1 1/2 hours altogether and very satisfying!
onward we go
XK4
I know this response is very late but if these brakes are very old from the late 1950's and early 1960's they used Girling Crimson brake fluid.
The DOT brake fluids would turn the rubber seals into a soft mush resulting in brake failure.
I've been out of the British car ownership for a long time so things may have changed since then.
PAUL161
JP, Girling Crimson brake fluid is NA. I've read that fellas with cars that used it are replacing it with Castrol DOT-4, check it out, I've never used it, but it is supposed to mix with other fluids. PJ
attachment.php
LarryK
I have been using Castrol DOT-4 for a long time. The containers used to be white. Bought the newer Rover and the specs were synthetic fluid for brakes, so I looked on line and ordered the new stuff in black container. Well, when I compared them, it was the same old Castrol as the white containers said synthetic too, Mixes well with other fluids, not the same as DOT-5 which is totally different. The Castrol is compatible with rubber or neopreme seals. Has a pretty good temperature tolerance. That is the only brake/clutch fluid in my shop.
JPSmit
JPSmit
Thanks all for this FWIW I will however be going with DOT5 as with the Midget, I know it is controversial but, I have had good luck, it saves the paint and the entire system will be new.
PAUL161
I have DOT-5 in the TF and it works very well, no issues. You do have to go slow when bleeding the system to prevent air bubbles from forming. PJ
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
A Brake Master Cylinder Freeplay Austin Healey 11
T TR2/3/3A TR3A Disk Brake Question Triumph 10
