im having a hard time refiting these knobs on the choke, heater, rheostat etc. In fact have broken the latter by pushing too hard in an attempt to slide it far enough so the pop pin engages the hole on the lever. Is there a trick to this, I suspect lubricant would help but am hesitant to use it, will warming the knobs in hot water help ?
Also Re the drain tubes that should be extended behind the front wings. What is the easiest way to get to them?
I want to replace all the instrument bulbs while the dash is out and cant find any at my local stores (Kragen etc) before i call moss to order them anyone know who might have these in stock in So Cal.
Lastly on a 69 tr6 I found only one of the 2 red warning lights between the guages in use, the second bulb holder was present but taped to the harness- I think its the one for the brake pressure warning light. Should this be present on my car and if so where is it-thanks in advance
