View RSS Feed
Recent Blogs Posts
  1. MGB wire wheel problems
    I am having problems keeping the wire wheels on my MGB tight. They loosen up and make a noise that sounds like a bad universal joint. I can tighten them to make the noise go away, but they become loose and the noise returns. Please advise me on how to fix this.
    Categories
    Uncategorized
  2. Triumph Roadster 2000
    Hello,Iím going to buy a TR Roadster 2000. As there are some works to do on it , I should like to take this opportunity to transform it from RHD to LHD.Do you know what parts I need to buy and where I can find them.
    Regards,
    Bernard
  3. Triumph Roadster 2000
    Regards,
    Bernard
    Categories
    Uncategorized
  4. Connections for a 'Service Warning Module' - 1976 MG-B
    I am rebuilding a 1976 MG-B that I purchased non-running. There are a few 'modifications' to the electrical system, particularly in the motor compartment.
    I found a module that is mounted on a bracket or the R/H side of the engine bay just ahead of the heater blower. There is a 'speedo type' cable from the transmission that goes into the bottom & another speedo type cable that goes from the top of the module to the speedometer. There is also a black sheathed wire set about 30 inched ...
    Categories
    Uncategorized
  5. TR3A door lock mechaninsm
    trying to disasemble the door lock and cannot get the smooth circular head bolt off of the door lock slide bar. it is a small bolt that goes thru some sort of lock washer but cannot get it apart
    Tom
    Categories
    Uncategorized
Page 1 of 42 1234511 ... LastLast
