bravenrace
I have a TVR 2500M, and would like to improve performance. Since this has a TR6 engine, I thought I'd ask hear.
The engine is in excellent condition, so I don't plan on a full rebuild at this time. I'm new to these engines, but not engines in general. I've done some research, and this is what I'm thinking about:
1. Pull the head, send it out for a reputable Triumph shop for porting, shaving, and a good multi-angle valve job. If I find the right place, I'll probably just follow their recommendations as to what to do with it.
2. Add a performance cam and valvetrain components. I'm think a GP2 cam here, but am open to recommendations.
3. I'm keeping my Stromberg carbs for now at least, but will tune them to provide the proper air-fuel mixture with the new setup.
4. Install either a Crane or Pertronix electronic ignition conversion, as much for ease of maintenance as anything.
5. Re-curve the distributor to optimize the other changes.
6. Improve airflow to the carbs via a fabricated ram air system.
7. Add a fabricated free flowing exhaust system.
How does this sound? Am I on the right track? Anything else I should consider or do different? Would a header help much? From the outside, the stock exhaust manifold looks like it might flow well enough on it's own. There's also the complications of fitting a header to the TVR chassis.
What kind of horsepower should I expect from this combo?
This will be an occasional street and road course car. I may consider vintage racing at some point, so I wouldn't want to do anything to it that would make it illegal for that, but I haven't looked into the rules yet.
Thanks,
Jim
Thanks,
Jim
