MGB-GT dumping gas
Sopwith_Camel
well I'm Dumping gas
so I replaced the jets and the grose jets. and i did one of the temp sensors
but the carburetors over flow is still dumping gas
I mostly have the cold weather screw adjustment in the wrong place after fiddling with it.
any ideas should i do the needles? it started on the cold mornings so I thought it was the temp sensors.
steve
PAUL161
Steve, Did you adjust the floats? PJ
Sopwith_Camel
Sopwith_Camel
there is an adjustment for them?
these are the HIF4 type
i first started seeing fuel dripping on cold mornings so i figured it was a temp sencer thing.
but ok ill look for a float adjuster.
steve
Sopwith_Camel
Sopwith_Camel
not seeing it in the hanes manual page 80.
I am susspecting something to do with choke and the cold weather stuff
steve
PAUL161
On HIF-4s, the float is in the bottom of the carb, not like the earlier models with the exposed float bowl. Here's a diagram of an HIF-4 and circled float assembly. To set the floats on the HIF-4s, the carb has to be removed from the engine. I've heard of doing the floats while on the car, but there's no way I'd try it! To delicate. PJ
I didn't add that a float could have a fine crack in it and could possibly have fuel in it. I had one do this. Best thing to do if this happins is to replace it with new.
Sopwith_Camel
Sopwith_Camel
yes i just had it apart so i know where it is.
but didnt I see an adjustment screw for it.
the crack seems possible. but the problem first started on cold mornings and it wouldnt happen in the after noon.
steve
Platinum
Look to the choke assembly seals and as Paul suggests, the integrity of the float, along with its needle and seat. The last two should be "hospital clean" to do their job.
Sopwith_Camel
Sopwith_Camel
ok both are over flowing
i got the engine up to temp and took off the choke and its still leaking
so thats this mornings research.
steve
PAUL161
Steve, have you checked your fuel pressure? These carbs can't stand much over 3 pounds of pressure.
Sopwith_Camel
Sopwith_Camel
no i havent
but i have run the car for a year now so it would be weird it it suddently went up?
one of the guys in the club did ad a fuel pressuer regualtor to his A
I guess i should do the same.
steve
PAUL161
no i havent
steve
Not necessarily, I'd just check the pressure and if it's at or below 3 lbs, I'd just leave it as is. JMHO. PJ
Sopwith_Camel
Sopwith_Camel
orded it already. i have a long delay so i tend to order quick to get stuff under way.
with any luck saterday i will get the carbs off the B and the carbs back on the Jag.
steve
Sopwith_Camel
Sopwith_Camel
ok it looks like the issue was the O ring on the choke so the carbs are back on and it is no longer dumping gas
i did put in a pressure regulator
I unfortunate fiddled with the folcurm screw for the tempiture sensor on one carb.
so that is my first candidate for why im down on power and it sounds like a VW Bus
yep its ideling fine on a little choke its just above freezing today
but when i pull the throttle it bogs down
steve
tony barnhill Gas Dumping Out on Ground Under Car MG 4
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 6
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
T magnets and gas tanks, and other applications Austin Healey 3
Michael Oritt Gas cap parts now in tank Austin Healey 17
Rhodyspit75 Bonnet gas struts Spridgets 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
