jmayzer
so i found a gearbox up in delaware, hooked it up to the engine, put it all back together and now, naturally, the problems start. the gearbox is locked up. at first i thought it was stuck in gear, but if i push down and then to the right really hard, i can get it to knock over, but not down actually into reverse gear. so as far as i know, i'm in neutral, but if i try and spin the driveshaft, rear wheels at the same time, rock the car back and forth, i get nowhere but a couple inches in either direction.
now the master cylinder had been emptied because i had to replace the slave cylinder and still need to replace the front brake lines. i have not yet bled the clutch line...that wouldn't make a difference, would it? i'd really like to discuss this whole issue over the phone with someone who has the time and familiarity with this year car. PM me for my number if you'd like to chat/could be of some help. cheers.
jake
jake
