TR2/3/3A Manual for the Laycock de Normanville Overdrive Unit
hit_n_miss
Member
I recently bought off eBay a manual for the overdrive unit that purported to be for TR2 through TR4. The Triumph Part No. for the manual is 502274. My concern is that the Forward for the manual says that it is for units fitted to the Standard Vanguard, Triumph Renown, and TR2. No mention of the TR3 (which I have). The manual also says that on the TR2, the overdrive only affects top gear.
In the TR3 Practical Hints manual, under optional equipment, they say that the overdrive applies to 2nd, 3rd, and top gear. That was my experience using the overdrive (before it quit working).
The eBay seller says that this is the correct manual for the TR3A (and other TR3s). I don't think it is; I think that this is an earlier manual. Thoughts? Comments? Does anyone know of the availability of the "correct" manual for a TR3A overdrive unit?
It's possible that this manual may be sufficient for me to diagnose / fix my unit (probably an electrical fault, possibly oil level).
Thanks. Arnie
TR4nut
Arnie-
I'm pretty sure that's the standard manual thats out there - the A-type overdrive design itself really didn't change from the earlier models. Just in case, have you ever met Ed Woods? I think he's in the Pittsburgh area and he knows more about these overdrives than most ever will - he may be a very handy resource for you to help you sort things out.
Randy
TR3driver
Great Pumpkin - R.I.P
As far as I know, that is the only separate manual that Triumph ever offered for the A-type. Yes, it is somewhat dated, many of the details are incorrect for the later cars (like operation in 2nd & 3rd, pressure specs and so on). There were several other modifications along the way, like larger operating pistons and a smaller accumulator (for the IRS cars). But it still has a lot of good information about troubleshooting, how the whole thing works, how to adjust the solenoid and so on.
Best factory reference that I know of is the TR4 workshop manual. Unfortunately it has little or nothing about troubleshooting. But there is a good article on troubleshooting written by a fellow enthusiast at https://www.buckeyetriumphs.org/technical/AOD/AOD5/AOD5.htm
Or you could ask here. Lessee, it must've been around 1975 when I bought a TR4 just to get the overdrive, and put it in my TR3A. I've been nursing one or another around pretty much ever since :smile:
PS, forgot the links. TR4 manual:
https://drive.google.com/file/d/0B2...YWExLWIyNjctOTYzNmI3OTg2ODM0/edit?usp=sharing
OD manual:
https://drive.google.com/file/d/0B2...N2Q3LWJmZTUtMTRkN2MxNDI4M2Vj/edit?usp=sharing
Another document that might be helpful:
https://drive.google.com/file/d/0B2H2NJt34OffcVp0TUJiU29Sa214cXVOQzJCTGJXUQ/edit?usp=sharing
Also, those old manuals recommend using 30 or 50 weight motor oil. Triumph changed their minds around 1959 or 60 and started requiring (as in void the warranty if you don't) 90 weight GL4 gear oil instead. Personally, I use RedLine MT-90 which is a full synthetic GL4 oil that has been optimized for use in synchronized manual transmissions. It didn't seem to make a lot of different to the OD, but sure made a noticeable difference in the main gearbox. Kind of pricey, but worth every penny, IMO. (Some shopping around may produce a much better price as well. I found it on Amazon for half what the local store wants.)
titanic
Nelson Riedel (the author of the Buckeye articles) used some of the info&drawings from the OD manual, in his writings, but his articles contain far more in depth info. The manual might be nice to have from a collector's stand point, but is not to helpfull for repair or overhaul. The VTR articles and the Haynes manual are also good sources.
Berry
H
hit_n_miss
Member
Thanks for the prompt and comprehensive replies. You folks never disappoint. Once I start the troubleshooting, I'm sure that I'll be back with more questions. :cool:)
Arnie
H
hit_n_miss
Member
Randy, I see that Ed Woods is also a member of the Western PA Triumph Association and I now have his email address. I'll probably contact him at some point. Thanks. Arnie
Arnie-
Randy
CJD
My A-type is on the rebuild schedule for December...as always I plan to be abnormally intense on a thread about it...
glemon
If you scroll down here https://www.acmefluid.com.au/larry/servicing.html you will get to a scan of the overdrive handbook for the Healey 100, it is the A-type O/D, some neat drawings of the mechanism and period artwork, but not sure of the practical value, the Healey unit was wired up differently with a throttle switch and a centrifugal switch which prevented it from turning on below 40 MPH or so, the throttle switch prevented it from disengaging unless you had part throttle engaged, the TR didn't have either of these, but the internals should be the same.
TR3driver
TR3driver
Hey Randall...all I get is the first page of your links. Is there a trick to it?
Shouldn't be any trick, but the magic doesn't always work. My suggestion would be to download the entire file to your hard drive using either the V icon, or File/SaveAs.
If that still doesn't work, let me know and maybe we can work something else out. This link should let you browse the entire collection:
https://drive.google.com/folderview...yMy00ZDhkLTliOWEtOWU1OWRhNDZhYmRl&usp=sharing
glemon
I have been using both Chrome and Internet Explorer lately due to problems with another forum and IE, in this case IE actually works better for viewing, in Chrome I don't get the scroll bar to view it, I think your only choice then is to download it to view it, I tried poking around and couldn't figure out any other way.
TR3driver
FWIW, Firefox works well for me. I particularly like the variety of add-ons that allow you to customize controls (like which sites can run scripts on your computer).
https://www.mozilla.org/en-US/firefox/new/
drustom Service or Owner's Manual? Jaguar 1
prb51 Bentley Manual Austin Healey 3
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
S For Sale Aston Martin DB6 Factory Parts Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale MG TD Factory Parts Manual on CD/ROM MG Classifieds 0
S For Sale MG TF Factory Parts Manual on CD/ROM MG Classifieds 0
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Austin Healey Bugeye Sprite MK 1 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Aston Martin DB6 Factory Workshop Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Sunbeam Alpine Factory Workshop Manual - All Models 1959 - 1968 Other British Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Jensen Interceptor and FF Factory Workshop Manual on CD-ROM Other British Classifieds 0
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
TomMull General Tech ST Parts Manual Triumph 8
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
A Wanted Manual Transmission Jensen Interceptor Other British Classifieds 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
S Wedge Tr8 manual Triumph 2
O For Sale AKD1179H 100/6 & 3000 factory manual Austin Healey Classifieds 0
G Looking for Austin 10 workshop manual Other British Cars 2
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
T Best Shop Manual for BE Spridgets 9
