TR4/4A timing chain and sprockets
grant tr4a
Hi all,
The timing chain tensioner broke on my tr4a, quite a bit of racket. How can i tell if the chain and sprockets need to be replaced or not. Also how do you tell if the chain is to tight or to loose. thank you grant
TR3driver
Great Pumpkin - R.I.P
It's hard to tell with the chain on the engine. But if you remove it, hold it sideways in your fingers, so the chain sticks out horizontally. It should have very little "droop" (flexing sideways). If the droop is significant, then it's due to be replaced. I was taught to replace the chain and sprockets as a set, since they wear together in service. Putting a new chain on worn sprockets will cause rapid wear in the chain.
That said, TR chains & sprockets seem to last a long, long time. I'd be seriously tempted to just replace the tensioner and let it go. In fact, that's what I did when it broke on my previous TR3A, even though it's a lot more hassle to get to the chain on a 3A. Not sure how many miles that engine had on it, but I put probably 200,000 more on.
Geo Hahn
As I recall from when I replaced my tensioner, the manual has a spec for the free play in the chain (how far you can press it in). You might also take a look at that.
Mine (unknown mileage) was within the spec and seemed okay (what do I know?) so I stayed with it.
Kleykamp
I recall seeing a spec for free play too. Seems like it was a measurement from a stud to the chain with the chain "compressed". Since all I have is a Haynes manual it may have been in it. I recently switched out short blocks and checked both engines. It was considerably less distance on the "new" one and the tensioner had only very light marks from wear. The older engine had significantly more play in the chain, more wear on the tensioner, but ran fine except for the crack in the block. I'm with using the chain as is unless you find some significant wear, or just want to tighten up a little while you at it. Seems the parts were not that expensive. Could be one of those "while I'm at it, for peace of mind" things.
G
grant tr4a
Hi,
I checked the chain slack and it is 9mm. I found a site with a diagram. Apparently 10mm is the max. The sprockets seem to have a small amount of wear. I am going to leave the chain and sprockets as is.
I do need a chain tensioner. Is stronger or upgrade tensioner available for sale. Thank you grant
Geo Hahn
I don't recall seeing any stronger alternatives when I needed one. On the other hand, the original probably lasted 100,000 miles.
TomMull
Check the cover too. The tensioner ofter wears a groove in the cover and occasionally the front plate. I'm not sure if that is really a problem (until it leaks) but I replaced my well worn cover. Tom
Geo Hahn
Check the cover too. The tensioner ofter wears a groove in the cover and occasionally the front plate...
Mine wasn't too bad but I have heard of them wearing right through the side of the cover.
glemon
First engine I ever tore into was on my old TR4A many many years ago, knew it needed pistons and liners and a valve job, didn't know enough to even check the timing chain and tensioner, it had worn through the tensioner and wore through the cover right as I was leaving for my first trip to the vintage races at Road America. Lesson learned the hard way.
Anywhoo, I was gonna say chains are cheap and I usually just replace them while in there, but looks like they have gotten a little more expensive, so maybe it is better to do some of the tests already mentioned. If the teeth on the gears are sharp and pointy that is a sign they are worn. I have sometimes just replaced the smaller crank gear, my cheap mechanic rationalization being it is smaller so the load is more concentrated, plus it is usually cheaper than the big one on the cam. By all means always replace the tensioner, they are cheap and do wear out.
charleyf
Hi all,
Did you get all of the pieces of the old tensioner out. I tore down an engine that was sidelined by that same thing happening. I found metal pieces in the oil pan.
Charley
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
doughairfield Timing chain sprocket to camshaft Triumph 9
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
