Oil cap shorts Ignition???
chazevans
I was tooling down the freeway last night when Gidget my 58 Sprite started to sputter and cough losing power intermittently . I started to pull to the side of the road and she starting running fine again for a couple of miles so I continued on. After a mile or so the sputtering became bad again and I pulled to the shoulder of the road and she came to a stop and would not start. A couple of misfires but no go.
popped the bonnet and saw that the oil fill cap had come lose and was resting against one of the plug wires. Any idea what may have happened such as shorting or worse yet frying something in my ignition system?
HELP!!!!
DanLewis
HELP!!!!
You don't say whether or not putting the oil filler cap back on (and getting it away from the ignition wires) corrected the problem, but if it did, then I would expect that there was no permanent damage. It does sound like you might need a new set of plug wires, however, if the spark was able to get through the insulation of the wire and ground against the cap.
'Hope that's all it was,
Dan
CLEAH
Same question as Dan had, but it does not sound as if one or even two plug leads getting shorted would kill the engine. Make it run rough, yes. Sounds like fuel starvation to me, which could be caused by a clogged filter or line, or a intermittently bad fuel pump (that is, if you are running an electric SU in place of the original mechanical pump).
Sarastro
Shorting out the high-voltage wiring (plug wires) won't damage anything. Even shorting out the primary wiring, between the coil and the distributor, shouldn't do any damage.
jlaird
Had this happen during a race one time long ago. Put cap back on and proceeded to next run which was the days fast time. Maybe metal oil filler caps are not the best way to go?
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
NutmegCT T-Series Loose valve cover oil cap MG 4
Got_All_4 TR2/3/3A Which oil cap decal is proper to use with this cap Triumph 7
max71 MGB The easy way to get the oil pressure relief cap nut back on MG 8
David Townsend TR4/4A Oil Cap Decals Triumph 6
David Townsend TR2/3/3A Engine Oil Cap Decals Triumph 0
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
A oil cap Triumph 11
D 948 Oil Cap Spridgets 5
M TR2/3/3A TR3 oil filter cap needed Triumph 8
bighealeysource Looking for a 100-4 valve cover oil filler cap Austin Healey 0
RAC68 Carb Oil Cap Loosens Austin Healey 5
brgrmyster GT6 Original AC oil filler cap 67-68 GT6 [also TR4A]? Triumph 1
K oil filler cap Spridgets 0
V TR2/3/3A TR-3B Chrome Oil Cap Triumph 4
P T-Series Looking for TD Oil Pump Top/Cap MG 0
V TR2/3/3A TR-3B Oil Filler Cap Triumph 5
CharlieCarpenter Gasket for oil filler cap??? Austin Healey 1
G Oil Filler Cap-Retaining Wire Austin Healey 11
L CAP NUT--OIL PRESSURE RELIEF VALVE Austin Healey 2
mjobrien Cap Nut on Oil locating screw Austin Healey 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
AUSMHLY Does the oil filler cap have a seal? Austin Healey 1
davidk Chrome oil filler cap Triumph 9
H OIL FILLER CAP Austin Healey 1
ncbugeye Smog oil-filler cap Spridgets 3
Nunyas Sealing a vented oil fill cap MG 6
curtis oil filler cap Triumph 5
Wana Oil filler cap - gasket? Austin Healey 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
