TR2/3/3A Correct Coil for petronix ignition tr3A
aserftr3
Hello all, I have made it to the point in my rebuild of installing my new petronix Positive ground ignition, at the same time I ordered the ignition I got the petronix flamethrower coil. I am questioning now whether that is the correct Ohmage coil to use with the ignition. Petronix paperwork calls out for a coil with at least 6ohm. the flamethrowers sticker reads .6 ohm. IF this is indeed the wrong coil to use what would be the recommended one? Thank you as always for any input.
Darrell_Walker
0.6 ohm is too low, unless you have the Ignitor II module (not even sure if they make that for your application).
I thought a 3 ohm coil was the typical recommendation for a 4-cylinder. Pertronix has this page on how to calculate what coil you should use:
https://www.pertronix.com/support/tips/#a2
Though it says for "negative ground only". I don't know if just making the right connections for your case would be sufficient, or if there is some fundamental difference in the positive ground setup/module that makes it not apply.
TR3driver
Great Pumpkin - R.I.P
I agree, you've got the wrong coil. Don't even try it, as the module will quickly overheat and burn out. The "Flamethrower" coil comes in three different resistances, you need the 3.0 ohm version.
In the link that Darrell gave, it is the procedure that is only for negative ground. The coil will work with either polarity; and the test will work if you make the appropriate adjustments.
I'm running a Flamethrower coil in my TR3 (3 ohm, with points, negative ground). Can't say that it is any better or worse than most other brands, but at least it hasn't crapped out and left me on the side of the road like the previous Lucas coil did.
Lukens TR2/3/3A TR3A coil. Correct resistance? Triumph 6
G Choosing the correct front coil spring Spridgets 54
J Coil spring free length & correct brake servo? Austin Healey 2
S Correct hookup for Pertronix and Lucas Coil? MG 3
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
