Electronically Adjustable Timing and Dwell
DanLewis
Has anyone else seen (or better yet, used) this device?
https://www.ebay.com/itm/310657886219?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
It requires that you have one of Accuspark's electronic ignitions, which I do, which was very inexpensive and which has been very reliable. The device listed above allows you to use your laptop to program your own advance and dwell curves.
Dan
dklawson
That's very interesting. I hope someone has used it (or will soon) and post their experience here.
DanLewis
DanLewis
nomad
I'm wondering how this gets a signal for what the engine is doing. Most system's that are fitted to carburated engine's use a TPS [throttle position sensor] along with tach signal to determine what your engine is doing. If you go WOT, you want your advance to fall back and at cruise you want max advance.
Kurt.
DanLewis
DanLewis
Hi Kurt,
That's not what this device does. There's no sensor input to the device and it's not a complete engine control computer. It simply allows you to setup whatever advance and dwell curves you want using a laptop. Once set, the distributor works like a regular distributor. If you don't like the settings, then you can always go back and reprogram new settings.
Dan
nomad
Yes, Dan, I guess it could overide what the fly weights normally do and give you a dwell curve but you would still need the vacuum advance mechanism. The stock mechanical advance curve is usually all in by around 3K and I always thought the only thing to really be concerned about on dwell was that the coil had ample time to recharge. Guess I don't see a need but am willing to be enlighened.
Kurt.
aeronca65t
That looks real interesting. Works on Pertronix too.
For me, I could map it for 10 BTDC for starting and then advance to 30 BTDC at around 2500 RPM.
Simple.
I like the rev limiter feature too.
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
kodpkd Adjustable Tie Rods Austin Healey 20
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
Walter74 Adjustable steering wheel removal Austin Healey 4
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
4tecdog Adjustable Steering how? Austin Healey 8
maxwedge5281 adjustable trunnion Austin Healey 15
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
brgrmyster GT6 Sourcing the adjustable control rod 69-70 GT6+ Triumph 1
J Armstrong adjustable lever shocks Spridgets 11
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
F Replacing the horn push adjustable steering wheel Austin Healey 7
H horn button for BN6 "non-adjustable" Austin Healey 4
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
bugedd Adjustable trailing arms? Spridgets 3
6 Adjustable lever shocks Spridgets 5
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
richberman Adjustable shock mounts or fixed? Austin Healey 16
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
