If you collect tools...
Geo Hahn
Actually, if I am reading the listing right, the Snap-On tool is not like a Click-Adjust. The Snap-On still has you using the traditional feeler gauge, it's function is to combine the work of the screwdriver and wrench into one unit that preserves the original setting until it is adjusted and then preserves that setting whilst the lock nut is tightened.
I just note what o'clock is the correct setting, then back off a bit before tightening estimating how much the adjustment screw will move (not much) as the lock nut gets its final tug. If I end up at the spot noted, all is well. Of course all valves get re-checked after adjustment whatever method you use.
TR3driver
Great Pumpkin - R.I.P
Looks like you are right, Geo. I thought at first that the spring loaded plunger must be for some sort of click mechanism, but it is apparently just to retain the socket.
glemon
I'm with Geo, do it the same way. The tools are interesting, but never had too much trouble using a screwdriver, wrench, and feeler guage.
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
Popeye Bojo trim tools Restoration & Tools 7
DrEntropy Came across these "tools" Lotus 2
M TR6 Tools? Triumph 14
B Road Tools Restoration & Tools 6
7 paintless dent removal tools? Restoration & Tools 8
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
7 No more Bosch tools for me Restoration & Tools 4
Michael Oritt Special tools for LBC'S Austin Healey 25
M TP Tools vs. Harbor Freight Restoration & Tools 12
JPSmit Interesting tools as gifts Restoration & Tools 1
BN6_2197 Question on tools and spare parts for lonng distance drive Austin Healey 28
bugedd Tools to travel with Spridgets 11
PC wanna buy Craftsman tools? Restoration & Tools 5
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
G General Tech What tools are these? Triumph 9
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
LarryK Whitworth tools Restoration & Tools 5
JPSmit New Tools - woo hoo! Restoration & Tools 15
PAUL161 Tools, Do We Need Them All? Restoration & Tools 12
aeronca65t Old tools = art Restoration & Tools 1
drooartz Tools needed to remove front & rear suspension Spridgets 24
Trevor Jessie Can't afford these tools, but I want to learn to use them Restoration & Tools 2
Gearhead Witworth tools Restoration & Tools 4
britlover Anyone in SE Michigan, or Northern Ohio with XJ 4.2 Cam removal tools to borrow? Jaguar 3
Banjo antique tools score Restoration & Tools 2
J knock, off tools Jaguar 6
S Tools valuation? Restoration & Tools 1
aeronca65t Sunbeam Tools Sunbeam (Rootes) 3
A Car Diagnositc Tools Restoration & Tools 4
J New Tools in my shop, need some lessons Restoration & Tools 31
Flash_Harry British Tools & Fasteners, LLC MG 1
RAC68 Convenient Homemade/Altered tools Austin Healey 18
Nunyas Pneumatic tools Restoration & Tools 8
M What tools can you see in this pic? Triumph 29
smaceng Eureka, all BE tools Spridgets 5
PAUL161 Chraftsman tools Restoration & Tools 13
W What tools for working on Healeys Austin Healey 17
I Picture of original bugeye tools? Spridgets 26
I Tools for tonneau fittings Austin Healey 8
5 tools for the LBC Restoration & Tools 20
Brosky Harbor Freight Tools New Years Day Special Triumph 5
AH3000MkIII BJ8 Factory Supplied tools Austin Healey 3
JPSmit Canadian Tire Tools on Sale Restoration & Tools 3
coldplugs Mystery tools Restoration & Tools 14
C Cheap place for tools, sjdiscounttools. Restoration & Tools 4
KVH Tinsters Tools--Front End Tools Triumph 1
JodyFKerr Tools & optional items Austin Healey 7
R Triumph tools Triumph 18
JPSmit shop tools Restoration & Tools 3
