MGB MGB smog control ????
Bob Claffie
As the 2 TR8's I had a opportunities on fell through I have started casting my line in the MGB waters. Last night while searching ebay I found several "inexpensive" MGB's any one of which would do as a project.
My observation of these cars brings me to todays' question. Invariably this group of six or eight B's , from 1968 thru 1979, were stripped of all the smog control. No air pumps, no air rails. Why is this ? I understand that it "neatens up" the engine compartment somewhat but also makes the car nominally illegal.
From the engineers and engine builders here, what is the rational ? Is there any substantial performance benefit ? I can't believe it takes more that 1 or 2 horsepower to run the air pump. What is the fact or fallacy behind this indiscriminate removal of equipment ?
We have had three MGB's in the family, one with and two without and remember no significant difference in performance or reliability. Potential owner wants to know. Thanks, Bob
Deleted member 8987
Personal experience, any car with emissions in that time frame suffered from loss of power and mileage with the emissions controls of the day.
I can tell you, but not tell you how I know, that removing cat, egr, distributor vacuum controls, air pump and injectors, made them run like the ones the year before the garbage was installed.
I have seen (same disclaimer) air pumps taken apart, gutted, and only a shaft and bearings spinning.....cats pulled and gutted, BB's in hoses, and under air injector lines.
How far back does Mass go on emissions testing? Up here, it's a 20-year sliding scale.
Usually, manufacturers added stuff to existing engines, so internals were pretty much the same.
Then they started in with swirl, combustion chambers, cams and all that rot.
They didn't get close to making them functional until computers and fuel injection.
We have tested internally stripped cars, and they are either the same or better on emissions in that era.
In mid 70's, big Lincolns with 460's suddenly wouldn't get out of their own way. Seriously.
Took one apart in the dealership once, found they had changed the timing gears, keys in different positions, marks to match.
Ordered out 460 Police Interceptor timing set, the car would light up the wheels for half a block.
When I was an emissions specialist, we had the papers handed to us in classes we had to attend, that California, which had stricter emissions controls than anybody else, used 10% MORE fuel for the amount of licensed vehicles than any other state in the union.
We pulled the garbage off, fuel economy increased by about....10%.
Go figure.
MG's should not have had emissions devices until later than what, 70? I can't remember anymore.
And early emissions (up through about 1970, 49-state) consisted of a PCV valve and thermactor air cleaner.
No cats, no egr's, no air pump.
Dave
Deleted member 8987
I thought I still had my "bible" on emissions controls. Listed by year and make what was required. We needed it from back when we had to do "visual" inspections, before our folks listened and realized visual made no difference...it was the tailpipe.
I do remember one other thing from those days...
Limits were hard....you failed by .0000001%, you failed.
Except for British cars.
No kidding.
British cars were exempt from the strict requirements....IF the owner had the original paperwork from importation (new or used) that stated specifically what the levels were upon acceptance for importation.
So, of you were allowed 3% of whatever, and your car was accepted with 3.75%, that was the number they had to use for go-no go.
Dave
drooartz
Bob, I can't speak for MGB emissions devices from that era (my MGB is a UK car that never had any of them) but I've had 2 different '76 Toyota Land Cruisers -- one with all emissions stuff removed, one with all factory emissions stuff present. Don't know if it made a lot of power difference, but boy the mess of vacuum hoses and vacuum switches and 1970's computers and... had I kept the second one (with all the factory stuff) I'd have put all that stuff on a shelf.
Utah does emissions tests by county -- and my county doesn't test. If I lived down in Salt Lake City still, I'd have gone with a car '67 or older as that's the cutoff here; no rolling cutoff, goes all the way back. May still eventually wind up with an older car so as not to worry.
Part of me would be interested to see if my car without any emissions pieces as from the factory would pass the 1970 emissions levels. Curious, but not enough to do anything about it. :smile:
Deleted member 8987
My 1950 Ford, flathead V-8, did just that. I still have the printout in the glovebox, 25 years later or so.
JPSmit
In terms of the B specifically, If my Midget is anything to go on, the emission stuff failed and/or needed to be replaced and the stuff wasn't there to replace it. I have seen a few cars with working smog kit and I understand that there are California clubs that keep engines to be swapped in for testing, but, it seems like many air pumps broke and were removed long before anyone thought about tearing out the smog stuff. Likewise, i know mine had gulp valves and charcoal canisters and ERG valves that needed replacing and/or re-setting at certain intervals - I have no idea where you could even get such things now.
Bob Claffie
Bob Claffie
I mostly agree with JP. As I reflect on our personal experience, I recall my son's MGB was "desmogged" due to necessity, his "gulp" valve failed and the air pump seized up. This may be what happened to the six MG's I chose to follow on ebay not a search for more performance or some other obscure reasoning.
I also agree with TOC, I have no love lost with Cat converters or vacuum retarding distributors, likewise lowered compression pistons. Actually most of our LBC's are driven so little (a few thousand miles a year) that the pollution we should be saving doesn't amount to a nit in the real world..
What triggered this thread was the across the board elimination of air pumps which ultimately may have been caused by the lack of replacement parts or their costs
Smog testing here in Ma is only performed on cars new enough to have an OBD2 computer testing plug. I "think" there is something on the books about a visual inspection of smog equipment on older cars but I have never seen it applied. As an aside, I DO have cat converters, air pump and carbon canister on my replica cobra, as I built it before replicas were made exempt from smog testing (it actually passed a couple times) but mostly to cut down on the sound of the exhaust. Bob
Deleted member 8987
It wasn't just British cars of the era that seized up smog pumps.
Geez, we used to change a lot of them..and the little narrow belts that drove them (specifically designed to snap when they locked).
Taking them apart wasn't all that hard, and the innards came right out. I knew guys who cut a new shaft, put new bearings in, and re-mounted....spun just like it was supposed to.....gutted the cat....looked like it was supposed to.....plugged the retard advance.....looked like it was supposed to....jammed the Thermactor valve on the air cleaner open from the inside...no more erroneous hot-air incursions heading through Beale's Cut or climbing the Ridge Route.
Look at the figures published for horsepower for 1967, then look at the same engine series as the years progressed.
I did that for a guy once...he was amazed.
Never did hear...does Mass have a fixed year or sliding scale for emissions?
Dave
PAUL161
Bob, The wifes 72 MGB has all the smog equipment in place and is in perfect working order. When I restored the car back in 05, I wanted it as it came from the factory. I have driven the same year with and without the air system and can tell you, there is no difference in performance of a factory stock engine! I'm talking street engines here, without any outside high performance equipment installed. Different year engines will have a different performance scale, but for the same year, there's no change. Here's a shot of the wifes factory original 72 engine bay. Only coil is later model. PJ
Oh, For the critics, I've known this car since new and it DID come originally with that fan on it!
Platinum
Is it on backwards, Paul?!?
Platinum
The early pumps had vanes that would get stuck in their receivers and either break or not wipe the bore they rode in. Vane failure was usually the reason for the pump being gutted to become just a shaft in the case.
PAUL161
No Doc it's mounted correctly. Here's a closer shot. The fan blades are cupped, as you know, to pull the air through with the most efficiency and to turn the blade around would be out of the question. This fan was to end in 1970, but as we all know, BL used some left over parts on next years cars and I believe that's why the car came with this fan on it. The car was bought new by a local doctor for his daughter to take to collage. When she graduated, she gave it to her sister for the same reason. After she graduated, the car was put in the back of the doctors garage and set there for a couple years before I got it. It set in my garage for 10 years before I started to work on it. So the fan has been a topic of discussion many times by the critics saying it doesn't belong on that car! I know different, but I let them rant if it makes them feel better. :highly_amused: PJ
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
D MGB MGB LE MG 5
