Results 1 to 15 of 15
Thread: Dash lights
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    480
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Dash lights
    Is there any way to increase the intensity of dash lighting? Seems like there is one small bulb per instrument and it only faintly lights the unit op when I put the dash lights on.
  2. #2
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,750
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    Cleaning the bulb's and guage windows made a difference on mine but I had things apart anyway. Not sure if its worth the trouble otherwise. I'm talking about the small guages with the separate bulb.
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  3. #3
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,098
    Thanks Thanks Given
    2
    Thanked in
    Re: Dash lights
    Little British Car Company sells some upgrades with more wattage and light, but it gets a little pricey to order multiples, you can get LED lights as well, but a little trickier to get the right ones, many are somewhat directional, like a flashlight, and you want one that diffuses light in all directions or a multiple LED light that shoots the light in multiple directions. If you want to venture out beyond the usual British car suppliers you are looking for a 12 volt bulb with E10 screw base. Google that or search on E-bay, all sorts of things will come up.
  4. #4
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Dayton, OH
    Posts
    5,220
    Blog Entries
    2
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Dash lights
    Cleaning and painting the inside of the cans white helps tremendously in reflecting light.
    Jim Gruber - Dayton, OH
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - Coming soon late Summer '17 - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new -
  5. #5
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    5,714
    Thanks Thanks Given
    3
    Thanked in
    Re: Dash lights
    Start with Jim's suggestion to clean and paint the inside of the gauge case. It does make a big difference.
    If that is not a big enough improvement for you, visit Britishwiring.com and look up their bulb holder C614. It uses the newer wedge mount bulbs instead of our car's traditional screw-in bulbs. With the wedge mount bulbs you have more choices for bulb wattage and you will be able to buy the bulbs locally. If you want to keep your original lamp wiring, consider using ScotchBlocks to tap into your old lamp wiring rather than permanently splicing the new bulb holders in place.
    http://www.britishwiring.com/Push-in...ube-p/c614.htm
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  6. #6
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    480
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    Guys, thanks for the responses. I will take advise and clean/paint white to improve "reflection". Also thanks for the site for upgrade wit\ring bulb holder.
  7. #7
    Darth Vader Rut's Avatar
    Join Date
    Jan 2008
    Location
    Tuscaloosa and Orange Beach, AL
    Posts
    2,575
    Thanks Thanks Given
    6
    Thanked in
    Re: Dash lights
    Someone posted a restoration of their gauges awhile back and it involved a strip of LEDs mounted inside the case along with painting the interior white. I've tried unsuccessfully to locate the thread, but would like to review it again.
    Rut
    Rut, '60 Bugeye, '70 MGB, '62 TR4, '66 TR4a IRS, '67 TR4a IRS, '68 TR4a IRS, '72 TR6
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down 'happy'. They told me I didn't understand the assignment, and I told them they didn't understand life. John Lennon
  8. #8
    Yoda RickB's Avatar
    Join Date
    Mar 2007
    Location
    Snoqualmie, WA USA
    Posts
    5,180
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    In a late model Midget where is the standard ground location for the dash lights?
    Mine have only intermittently worked since I've owned the car and I'm thinking there's a ground lug under there that could use attention.
    '80 MGB roadster - pageant blue with Overdrive
    '73 RWA car + rust free tub and parts - going to build an Arkley SS!
    '78 Midget - Datsun A15 with HIF4's Dogleg 5 Speed Bugeye Bonnet with Heated Miata Seats
    '80 Datsun 210 w/60 series 5 speed
  9. #9
    Join Date
    Dec 2006
    Location
    Dayton, OH
    Posts
    5,220
    Blog Entries
    2
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Dash lights
    Rick,
    It more likely is in the Light Switch. Those do come apart and you can clean the green out of them. There is a picture of a heater switch I disassembled and cleaned and successfully put back in service at Gerard's WebSite. Hmmm, headlights then are ok, no intermittent with headlights. Could be in the switch but I'm back to thinking about an intermittent ground for the dash as they are all run to a common ground.
  10. #10
    Yoda RickB's Avatar
    Join Date
    Mar 2007
    Location
    Snoqualmie, WA USA
    Posts
    5,180
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    Quote Originally Posted by Jim_Gruber View Post
    Rick,
    I did replace the light switch with a NOS Lucas light switch early on as the car came without a switch - or more accurately with a lump of melted plastic that was once a light switch.
    Most of the new switch's life it has been a switch that triggers relays for the headlights so those have always been fine.
    The issue is with the dash lights. When they come on they are good and bright (as bright as any lbc dash lights I've ever seen).
    The trouble is that they are intermittent, and more likely to come on during a really good rain storm than any other time.
    Thus - I want to know where the common ground point is under the dash of a 78 Midget.
    I have been under and back behind there quite a few times but haven't seen it yet.
  11. #11
    Join Date
    Mar 2005
    Location
    Posts
    5,714
    Thanks Thanks Given
    3
    Thanked in
    Re: Dash lights
    I don't know of the specific location for a ground terminal on the gauges but it is not uncommon to make a ground wire jumper string. All you need is a length of black wire and a bunch of ring terminals. You put a ring terminal on one of the mounting studs for each gauge and run a length of black wire from terminal to terminal. Then run the final length of wire off to a good earthing point on the chassis somewhere behind the dash.
    Doug L.
    '67 Triumph GT6 Mk1
  12. #12
    Jedi Warrior bthompson's Avatar
    Join Date
    Jun 2008
    Location
    Belmont, NC
    Posts
    593
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    My lights brightened a good deal (which is to say, from very dim to Lucas dim) when I cleaned all the connections and made sure I was getting full voltage at the lights. The combined resistance had pulled my gauge lights down to about five volts. I bypassed the dash dimmer switch as well, which gave me more voltage at the bulbs.
    Rick, it's been awhile since I had my dash apart, but IIRC the lights ground through the body of the gauges, and then through the dash to the body. I don't think I saw a separate ground strap for the lights. Maybe running a ground strap from the body to the dash would help? Doug's solution would work too; it would certainly guarantee continuity.
    Bill Thompson
    ''Nigel the Wee Beastie,'' '76 Midget 1500
    ...If your spridget doesn't leak, it's out of oil.
  13. #13
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    480
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    Think I will put the volt mater across the wires and see what volts are coming to the light bezel. IfI can then run a fused wire from the fuel box to the light if necessary as well as a better ground.
  14. #14
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Kirkland, Wash., USA
    Posts
    5,630
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    The absolute fix is a torch (flashlight) clipped under the dash.
    Pull and use as needed.
    Remember, Lucas invented dash lights with three positions....dim, flicker, and off.
    Plus they inadvertently invented intermittent windscreen wipers.
    Rick- Have you bypassed the dimmer?
    Dave
  15. #15
    Yoda RickB's Avatar
    Join Date
    Mar 2007
    Location
    Snoqualmie, WA USA
    Posts
    5,180
    Thanks Thanks Given
    Thanked in
    Re: Dash lights
    Quote Originally Posted by TOC View Post
    Dave
    One of the first things I did when I got the car.
    When they come on they are bright, they just don't make an appearance very often.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
