TR6 Need help with '74 TR6 speedometer.
2wrench
Hello, to everybody. I've been off the Forum for a while, but now I'm back and looking for some assistance.
My speedometer is not calibrated properly after installing my overdrive. I took it to a mechanic who looked at it and
said: "You need a new speedometer head."
Okay. So can anybody point me in the right direction to get a speedometer head? I would think that if a good speedo shop
could rebuild what I have, that that is what would have been recommended.
So what is the best course? I have not seen anything on line nor at the usual parts suppliers.
Any help is appreciated.
BobbyD
dklawson
Or... visit gaugeguys.com (APT) and have them build you a ratio conversion box so you don't have to touch your speedometer at all. The ratio box converts turns-in to the needed turns-out so your existing speedometer and odometer will read correctly. General prices ($95 to $125) are on their web site.
https://www.gaugeguys.com/speedcorrect.htm
JerryVV
Installation of Overdrive should have no effect on the speedometer as it connects behind any gearing. Why do you think it's changed? Did you change the rear end ratio? That would have an effect.
TR3driver
Great Pumpkin - R.I.P
That is true enough, but not all TR6 gearboxes and overdrives have the same speedometer drive ratio. Early TR6 (and previous TRs) all had a 5:2 ratio in the speedo takeoff, but later TR6 had whatever ratio made the speedo calibration come out to 1000 tpm. I'm guessing that 2wrench's OD came from an earlier TR (or some other car entirely, Volvos are popular donors).
dklawson
2wrench
2wrench
A huge thank you for each of your replies and input. I am a bit embarrassed to admit that what I finally did was to pay the Palo Alto, CA speedometer shop to
repair/rebuild/calibrate my speedometer. It works well and I am happy with it. It was a pricey repair, though. $500! I just wanted it done so badly that I paid the price.
After downloading the PDF and thumbing through it, I knew it was time to pay up and just get this thing done. Now I have returned the car to the Pros once again to
address heater core issues. Wishing you all a very Happy and Prosperous New Year!
2wrench
2wrench
I liked the sound of this, Doug, but I have had such a fit getting the speedo angle drive installed without leaks that I would have been reluctant to
"mess with success."
2wrench
2wrench
Right, Randall. I bought that overdrive off the net from a gentleman selling rebuilts at very good prices. Problem was, I really didn't know its history. Made it a little
more interesting.
martx-5
A few days after I finally got the restoration done on my TR3, I figured that it was time to see how far my speedometer was off, as I had made a couple of changes in the car that would affect the reading. I had installed the HVDA Toyota conversion, and also changed the tire size to 185/70-15. I stuck my GPS on the windscreen and set out to see about how far off the speedo was. I brought the car up to 30mph according to the GPS and glanced at the Jaeger speedometer...oh my, it read 30mph. Well, that just at slow speed, right?? Let's go faster...40 mph, then 50, then 60, all the way to 85 mph, and that Jaeger instrument read exactly the same as the GPS.
I got lucky with two changes that surely would have resulted in speedometer error just happily canceling each other out. Go figure.
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
I TR6 Need help on 69 TR6 glove box info Triumph 0
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
I TR6 Boring subject, but still need help TR6 trim rings Triumph 6
I TR6 Need more headlight help, TR6 Triumph 4
F TR6 Need help w/TR6 oil cooler install... Triumph 16
DNK TR6 Need help with a TR6 Tunnel lamp Triumph 12
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
boxofparts TR6 Tr6 Down Draft Webers - need help Triumph 2
G TR6 Need help on tr6/250 top install Triumph 4
H TR6 TR6 Timing- Need help please Triumph 2
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
Slider748 TR6 Help - need dimension of front end clearance [TR6] Triumph 3
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
