Changing Brake Fluid & Brake Pressure Switch
PeterB
Can anyone give advice on which brake fluid to use in a BJ7. Also I have to change the pressure switch for the brake that controls the brake lights and I was wondering if anyone uses any type of thread sealant?
Thanks
BJ8Healeys
Hi, Peter -
Which brake fluid to use is a hotly-contested subject in the Healey world and everyone has their own opinion. Some people swear that the only fluid to use is DOT 3, as original. I switched from DOT 3 to DOT 5 (silicone) in my BJ8 in 1989 when the car arrived home after a fresh paint job. Having spilled my share of DOT 3 on paint in the past, my primary purpose in changing to silicone was to avoid damage to the paint. For cars that are not driven frequently and spend a lot of time resting in the garage, another advantage of silicone is that it does not absorb moisture from the atmosphere and result in rusting of the system components. If you don't mind fluid spillage or flushing your system regularly, DOT 3 is fine.
I always use Teflon tape on threaded connections, if not for sealing then to prevent seizing of the threads when it comes time to separate the connection again. When I used a stock pressure switch in my brake system, I put Teflon tape on the threads of the switch. However, the pressure switches available today don't seem to last very long, so I changed to a mechanical switch instead of the pressure switch.
RAC68
BRAKE FLUID
The great brake fluid debates have raged since before the first internet was invented. For almost 30 years I used and was satisfied with DOT 3 in my Healey. Only after a full brake system rebuild did I change to DOT 5. My choice for Silicon was based upon my much-reduced use of my Healey and its increase in hibernation time.
Since DOT 5 is not subject to absorbing water vapor, internal water-caused corrosion brake system internals are much less subject to corrosive deterioration. After a 24 year period of no-maintenance installation, a mysterious loss of a relatively small amount of fluid with no deterioration in brakeing, and a 30% discount in brake parts from Moss, I decided to rebuild all brake components. When examining each component during tare-down, I found ALL components to be in very close to pristine condition with no observable requirement for rebuild. (The fluid loss was finally found this week coming from the brake master cylinder where the seal would expand and seal when activated and seep slightly on contraction.)
My recommendation is for Silicon DOT 5 for Summertime Healeys an DOT 3,4, or 5.1 if you have used these fluids previously and are not rebuilding all components or you have no problem doing a full flush every 2 years. Last, the price of Silicon DOT 5 is much more expensive than DOT 3,4,5.1 and I recently purchased a pint at NAPA for $17 and a quart from Amazon for $14 + $13 shipping. Considering my present age and the longevity of my past rebuild with DOT 5, I see my brake system effort as my last.
BRAKE SWITCH
After replacing my original pressure brake switch after 30 years and then 3 Moss switches within the next 6 years, I decided to install an electric brake switch in parallel. Scavenged from a salvage yard, my electrical switch was mounted on the plenum under the dash and activated by the foot peddle arm. I suggest changing to an electrical brake switch as its response and maintenance is far superior to the Healey’s original pressure switch.
Hope this helps,
Ray (64BJ8P1)
BJ8Healeys
More details about my change to silicone fluid and a mechanical brake switch:
As stated before, I made the change to silicone in Apr 89 after draining the DOT 3 and flushing the system with rubbing alcohol. I rebuilt the clutch slave and master cylinders before refilling with silicone. Found RH rear brake cylinder leaking in May 92. Against all conventional wisdom, I honed the cylinder and installed a repair kit. Brake master began leaking in Sep 92. Against all conventional wisdom, I honed the cylinder and installed a repair kit. Replaced the clutch slave in Apr 03 along with the hose since someone gave me a new cylinder. No maintenance actions on the brake or clutch hydraulic system since then, other than inspections. I have put 97,326 miles on the car since conversion to silicone, so it works reasonably well for me. I probably should have but have not flushed the silicone since initial installation.
I replaced the hydraulic pressure switch (which has to remain in place to seal the union it is screwed into) with an adjustable mechanical switch from Watson's Street Works, Bozrah, CT. It was expensive for a switch, at $22 plus shipping, but is well made and I have had no problems with my brake lights not working since I installed it and got it properly adjusted. I went through two Moss pressure switches in short order before changing to the mechanical switch. Watson's opinion is that the pressure switch contacts do not "wipe" each other and build up oxidation. The mechanical switch contacts do wipe and so keep themselves clean. Of course, build quality also has something to do with longevity.
Brake fluid:
Using Teflon tape on industrial hydraulic tube connections is a no-no, and I'll just leave it at that... :wink:
This is the brake light pressure switch on the last BJ8 I worked on; please note the copper sealing washer seated on the mating taper surfaces. I expect getting a correct replacement is nearly impossible, so if yours is still fitted with one, DON'T LOSE IT! A copper sealing ring is easily annealed, lending itself to a lifetime of re-installations, if need be.
BJ8Healeys
Yes, Randy, I know <span style="text-decoration: underline">industrial</span> hydraulic rules frown on Teflon tape. But the local Byers code has no problem with it. :thumbsup: I've never had a taped joint fail on me, nor rounded off the nut of a previously-taped joint in a fruitless effort to get it apart. I have, however, destroyed nuts trying to get apart non-taped joints. :madder:
GregW
Platinum
Hi Steve,
The teflon joint won't fail because the seal is at the flare, not on the threads. The problem with teflon is when the tape gets into the system and blocks something.
BJ8Healeys
Right you are, Greg. I use the tape on all threaded joints, flared or not, and not so much for sealing properties but for anti-seize properties. For joints that are broken frequently, such as the oil drain plug, the gearbox and overdrive drain plugs, and the rear axle oil fill plug, I always make sure that any residue left in the male and female threads is removed before re-sealing the joint. Using Teflon tape is just the way I prefer to do it and have done it for 30 years, and it works for me.
Richard Dickinson
I bought a set of non-Girling master cylinders from Moss (probably a mistake) but the instructions that came with them said the warranty is void if silicone fluid is used. Why would this be?
BJ8Healeys
The seals may not be compatible with silicone fluid.
Bob_Spidell
Beats me. I bought a clutch M/C with similar warning and installed it, bled, topped up with silicone fluid and went on a 4,000 mile road trip.
Have heard credible stories of people having trouble with initial install of DoT 5, but if the install goes OK people seem to do fine for many miles.
bighealeysource
Bronze
Like Randy said, so not lose that copper washer as you will not be able to find a replacement. I tried everything on my BN6 when I had to replace the brake light switch and could never get it the new one to seal properly. Ended up going with a mechanical switch from Watson as Steve Byer mentioned. That worked great and put the old switch back to close up the hydraulic circuit.
Regards,
Mike
steveg
DOT 5 has to be compatible with the seals or it wouldn't be certified by the DOT - there is info on this online.
I have a successful install of it via the brute-force method. All new rubber in all my calipers as well as flushing out all my lines and new Moss clutch master and slave and new Fiat dual master cyl. Calipers and lines were flushed with a couple of cans of brake system cleaner, then blown out with compressed air. I assembly-lubed the calipers with Dow-Corning Silicone O-Ring & Valve Grease. I used a modified version of Randy's recirculating bleeder tube to "bench bleed" the master cyl in situ.
IMO the problems come when people convert existing systems keeping the DOT 4 rubber parts and maybe not cleaning things out too well.
It's great to never again have ruined paint.
Joe Schlosser
I always thought that the copper sealing washer was used if either the switch or the "T" was scratched or damaged so it would not seal properly.
RDKeysor
Bronze
I used a Watson electrical brake light switch on my since-sold Jaguar MK2. The one I purchased was a difficult application, but it worked well. The guy who bought the car told me that he had done a lot of advanced electrical work on that car, including removing the points from the fuel pump, etc., but had kept the Watson switch I installed. I think Steve G and others have posted switch conversions that are much easier than the one I used, and probably less expensive. The neat thing was that it was a simple thing to convert back to the original switch simply by switching the wires if necessary.
shortsguy1
I have installed two BJ8 brake pressure switches recently (don't ask why!) and never used the washer shown above. Both have sealed just fine. So maybe the washer isn't always needed, or maybe my system has the washer wedged inside the female fitting. I always thought those types of fittings didn't need washers (like elsewhere in the brake system).
As an aside (unless I am mistaken), there are two types of brake switches used on our cars. I think (and please correct me if I am wrong), the older cars have a switch with threads like shown here:
https://mgaguru.com/mgtech/electric/et119a.htm
And then later cars have longer threads with the tapered tip as Randy shows above. I mistakenly bought the wrong type when I first tried to fix my brake light problem.
Healey Nut
Brake fluid:
The copper seal ring that Randy is referring to is readily available at any good HVAC wholesaler but you will probably need a freindly HVAC tech to buy them for you as most HVAC supply houses will only sell to guys in the trade .
they are used on 1/4” and other size copper flare fittings where the flare nut attaches to a device of a different material (steel/brass etc) in refrigeration/AC systems.
they should always be used where dissimilar materials are put together and a high pressure seal is required . Its basically a gasket .
B Changing to Silicone Brake Fluid Spridgets 18
W Changing Brake Fluid & Engine Oil Austin Healey 40
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
G Changing Horses in Mid Stream.... Triumph 47
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
T Changing front bolt pattern? Triumph 9
19_again changing right angle drives MG 1
G Changing my Sway Bar Triumph 11
