TR2/3/3A How do I install the headlight rings on a TR3 ???
rusty55
We've got the new headlights installed and adjusted. We have the new rubber and chrome rings but we cant get the rings to snap on. We've turned them every which way and no luck. It's a '60 TR3B so no set screw like the earlier models.
Thanks
CJD
There are two tabs riveted onto each ring - about 180 degrees apart. One tab clips near the top of the light fixture, and the other snaps into a spring clip near the very bottom.
Let me know if this is clear as mud...and I'll go take some pics.
John
TR3driver
Great Pumpkin - R.I.P
I usually find that I need to take the removal tool and use it to push the tab into the clip. Otherwise it tends to bend instead of going into the clip.
sp53
It is a very tight press on pop fit. Make sure there is enough room on the headlight bucket frame because if you have adjusted the lights back too far the ring cannot go down and if you have tightened the bucket too tight against the rubber on the bug eye there is not enough room either. you need wiggle room. Moreover, if there is paint buildup on the buck the ring cannot slide down very good. And make sure they are the correct rings?
Steve
PSUTR3B
I had the same problem. I bought at least two rings and could not get them to snap in place. Tried to bend the tab to make it fit but no luck. Tab broke off. several guys at car shows tried and all failed. Finally I got the top to fit and drilled a hole at the bottom and inserted a screw very carefully. Strangely the left ring snapped right in place. Now I am scared to take that one off for fear it will not snap back. The idea of using the removal tool to help make it fit did not occur to me. Good luck.
Gary
TR3driver
rusty55 said:
what is this removal tool?
It's just a strip of flat metal, with one end turned up in a lip. Roughly the same size & shape as an old PC slot cover (but the lip is not as tall). Item GT6 here https://trf.zeni.net/TR6greenbook/96.php
I use one I made from an old hacksaw blade, by grinding off the teeth and heating with a torch to turn up the lip.
Normally the lip is used for levering the trim rings off, by sliding it between the ring & the rubber gasket at the bottom, and then levering sideways to pop it apart. But you can also turn it around the other way and slide it in between the trim ring and the lamp retaining ring, to push on the tab and help snap it into place.
DougME
To install my rings I pressed down quite hard with the palm of my hand on the top of the ring, thus pushing the bottom down enough to snap on.
I made a removal tool by flattening out the end of a short piece of welding rod and bending the proper hook on it, then making a loop on the other end for pulling, works great. just cold working, no heat.
Doug, ME
64 TR3-B
60 Land Rover IIA
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
CessnaTPA Tonneau Install Question Austin Healey 13
G TR4/4A Interior Install...and other random questions. Triumph 11
S TR2/3/3A install the OD relay Triumph 3
steveg Wiper motor install error - warning Austin Healey 9
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
G TR4/4A Interior Install Steps Triumph 3
