Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: TR6 courtesy light wiring help
  1. #1
    Join Date
    Dec 2005
    Location
    Washington State, USA
    Posts
    1,957
    Chats
    I am trying to get my courtesy light hooked up in my 69 TR6. I found the purple/white wire going to the courtesy light switch on the passenger side door, but can not find a wire going to the driver side courtesy light switch. Can someone tell me where this wire might be or where it originates from? The PO has done some interesting things with the wiring such as cut wires off to the courtesy light way up into the harness and then retape it. Any tips or information on finding the wire would greatly be appreciated.
    Kevin
  2. #2
    Great Pumpkin DNK's Avatar
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    Re: TR6 courtesy light wiring help
    There should be 2 wires to that and a black wire 2 (also)
    Don
    "Stick a Wedge in it!"
    Mount Pleasant,SC
  3. #3
    I beleive the PW wire is is common to BOTH swithes.
    edit: if you look at the driver's and passenger door swithes, you should see one switch that has two PW wires on one contact.
    Elliot
    Central PA
    1976 TR6 White/Biscuit interior SOLD
    1973 TR6 Damson Plum / Biscuit interior, HVDA 5-speed, Good Parts Hubs
  4. #4
    Join Date
    Dec 2005
    Location
    Posts
    1,957
    Chats
    I am not sure if I was clear. I found the P/W wire to the passenger side switch. I found the purple, black, and purple/white wire going to the courtesy light itself (The PO cut the purple and P/W wires half way back in the wiring harness going to the courtesy light and then rewrapped that whole part of the harness - took me a while to figure out he had done that!). What I can't find is the P/W wire going to the driver side switch. My guess is that the PO may have cut the wire and rewrapped that part of the harness like he did on other wires. It is not as simple in this area since there are multiple sections of wiring harness. If I at least knew where the P/W wire originates that goes to the driver side switch, it would narrow down my search. Any tips or suggestions are appreciated.
    Kevin
  5. #5
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    I think I have this right and I am sure someone will correct me.
    The way lights work on these cars is by creating and breaking grounds with the body .
    The P/W starts at the light, then goes to the drivers door. then goes across the dash to the pass. door. Easy to fix by just unhooking the old and adding a new wire .Or, my thinking, untaping the old and fixing the problem.
    What ever way you choose that's the deal
    Don
    Mount Pleasant,SC
  6. #6
    Obi Wan hondo402000's Avatar
    Join Date
    Mar 2006
    Location
    Charlotte, NC
    Posts
    2,111
    Chats
    yes you would be right, the light comes on by opening the door and creating a ground, took me a while to get mine to work and I ended up buying new door switches because my PO took the switches out, heck I ended up rewiring the whole car and now EVERYTHING WORKS,
    door lights, tunnel lamp, glove box light, hazzard lights, oil light, PDWA lamps. even the rehostat works after I glass beeded the switch
    Happy with my rewire job
    It Is What It Is
  7. #7
    Join Date
    Dec 2005
    Location
    Posts
    1,957
    Chats
    Thanks for all the information. Does anyone have access to their car where they can see where the p/w wire comes out of the wiring harness to the driver side switch? If someone could post a pic or describe this it would help me out greatly.
    Kevin
  8. #8
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    Right next to the switch I imagine Kevin, or pretty darn close!
    Hold the show....
    That wire should be on the dash side of the connector correct????
    Don
    Mount Pleasant,SC
  9. #9
    Join Date
    Dec 2005
    Location
    Posts
    1,957
    Chats
    What do you mean that it should be on the dash side of the connector? One of the problems is that I understand in theory how one switch works with the courtesy light, but do not understand in reality how they are all hooked together. I used a test light to locate where the wire goes into the plug (located on the driver side)from the passenger side, but for the life of me can not find the other wire on the driver side so far. Maybe I am overthinking the whole thing and should just start unwrapping the harness? I will post a picture tonight to show what I am talking about.
    Kevin
  10. #10
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    Kevin ,right below the door switch there is a connector that "connects" the rear harness to the front. I was trying to remember if the drivers door switch wire was on the dash side of the connector or the rear harness side.
    Here is how it works
    The light has 12 v. ALL the time via the purple wire. All purple wires are battery fed.
    When you open the drivers or pass. door the switch closes and "goes to ground such creating the circuit.
    So the P/W wire is the one that creates the circuit on the doors.
    Have you pulled back the kick panel carpet on the drivers side?????
    Don
    Mount Pleasant,SC
  11. #11
    Join Date
    Mar 2006
    Location
    Charlotte, NC
    Posts
    2,111
    Chats
    is your tunnel lamp still in the car and does it work?
    Hondo
    It Is What It Is
  12. #12
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    Keith, details,details!!
    Don
    Mount Pleasant,SC
  13. #13
    Join Date
    Dec 2005
    Location
    Posts
    1,957
    Chats
    Don, the panel is already off. I have a full view of all the wiring.
    The tunnel lamp is what I am calling the courtesy light. I had a spare hooked up to test it and it started smoking. I quickly turned off the battery. It was dark, I was tired, and I should have probably stopped that evening. I may have just hooked up a wire incorrectly. I really don't want to try it out my second light until I am sure what the PO did with the other p/w wire to the driver side switch. I guess I could test the light itself. I would guess the black is ground. Would I just hook up the purple to the positive side of the battery?
    Kevin
  14. #14
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    Burned my spare one too.
    Here is the connector. Sorry it's so small. Look on this connector on your car. See if there is a P/W wire on it
    Don
    Mount Pleasant,SC
  15. #15
    Join Date
    Nov 2017
    Location
    Wyoming
    Posts
    9
    Chats
    I have a 69 and found this old thread.I have a wiring diagram but need assistance.
    Have no power to door switches, tunnel lamp or trunk/boot lamp.The glove box lamp works fine. The wirings not butchered.
    The horns are purple wire also , not hooked up but don't think that has anything to do with the problem.
    Any ideas appreciated!
    www.advanceautowire.com/tr2506.pdf
  16. #16
    Yoda tomshobby's Avatar
    Join Date
    Apr 2006
    Location
    Windsor, Wisconsin
    Posts
    3,848
    Chats
    So, to throw in a monkey wrench. When changing my 76 to LEDs I found the footwell lamps to be positive ground after several hours of trying to find why they didn't work.
    Tom
    76 TR6
    74 Midget
    www.madbrits.org/
    www.mg3club.org/
  17. #17
    Join Date
    Nov 2017
    Location
    Wyoming
    Posts
    9
    Chats
    Wondering why a purple comes from the ignition swiitch. The things not working should work ignition on or off. looking at the diagram it shows a purple from fuse box and ignition switch meeting up.
  18. #18
    Join Date
    Sep 2005
    Location
    Mount PLeasant SC
    Posts
    17,245
    Chats
    1
    The reason a purple comes off the switch is that it doesn't come off the iggy switch
    Don
    Mount Pleasant,SC
  19. #19
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,573
    Chats
    You should have a brown (always hot) wire feeding the fuse for all the purple wires.
    The brown wire originates from a terminal block. See if you can trace the brown/red wire on the alternator to the terminal block.
    You may find it on the driver side inner fender...not far from the fuse box.
    DRIVE 'EM IF YOU GOT 'EM
  20. #20
    Join Date
    Nov 2017
    Location
    Wyoming
    Posts
    9
    Chats
    Quote Originally Posted by DNK View Post
    If you look at that diagram in my first post is shows a purple from a round thing not sure what it is, it intersects with a purple next to the glove box in the diagram. But yes theres no purple on the ignition switch. Mistook the round thing for ignition switch, any idea what that is, might be the ptoblem?
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
