Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: Our Jensen Healey restore project, many questions.
General discusssion about other British cars that don't have their own forum (yet).
  1. #21
    Jedi Knight JodyFKerr's Avatar
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Re: Our Jensen Healey restore project, many questions.
    Most likely the stromberg has a bad diaphraghm or the pring inside has been messed with. Propbably the former item. You can, if you're clean about it, replace that bit with the carb on the engine. If you want to pullthe carbs, they aren't hard to rebuild, but there's a bit of a trick getting them synchronized correctly.
    Jody
    Website: http://www.theymightberacing.com/
    1953 Studebaker Champion, 1960 Austin Healey BT7, 1969 Austin Healey Sprite MK IV, 1970 MG MGB, 1974 Jensen Healey MKII (2), 1978 Triumph Spitfire (2), 1980 Triumph TR7 Spider, 1981 Triumph TR-8 (driver-ish)
    Farm: http://www.ScottishThistleFarm.com/
  2. #22
    Freshman Member 03RedSRT4's Avatar
    Join Date
    May 2011
    Location
    El Centro, CA
    Posts
    22
    Thanks Thanks Given
    Thanked in
    We will look into rebuilding them, Unfortunately I have to leave this to my dad for the time being, as I will be leaving for Oregon and Washington on Friday. On a side note, It sure would be nice if the engineers had made the hood to rise higher. It takes a toll on your lower back to work on this car, I have been doing most of the work on my knees.
    This site is awesome http://www.carbkitsource.com/carbs/t...g/2barrel.html but we are not sure which model Strombergs we have. How can I tell? Those exploded views and descriptions are pretty sweet. I need like, "Stromberg 101" my Edelbrock came with a DVD that made tuning and adjusting dummy proof, I have a feeling it's just as easy with these, once you have the knowledge under your belt. If someone can point me in the direction of a manual, preferably a pdf, or How To on the rebuild, I am sure myself or my dad can rebuild these. I see that Summit has rebuild kits, but I need to know my model number first. We are not with the car, but I can make a trip to it to read nay numbers stamped on it, unless someone can say which models we have based on my photos. Hmm??
    "73 Jensen Healey - "64 Impala - E85 powered "03 nSRT-4
  3. #23
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    Most of the Stromberg info I see on that site is for earlier carbs. I didn't see the 165s that are used on the Jensen Healey. Order the rebuild kits from Delta and then go on YouTube and search for "university motors stromberg" there's a three part series where they rebuild a Stromberg as put on an MG. Very similar to the JH excepting for the linkages.
    I had a step by step photo catalog of rebuilding JH Strombergs, but I can't figure out what I've done with the photos.
    Jody
  4. #24
    Obi Wan PC's Avatar
    Join Date
    Jun 2003
    Location
    SoCal
    Posts
    2,289
    Thanks Thanks Given
    2
    Thanked in
    US spec JH's have Stromberg type 175CD carbs.
    For me, the height of the bonnet has been less of an issue than the latch. If I don't remind myself to wrap a shop towel around it I'll end up with a divot in my head.
    pc
  5. #25
    Join Date
    May 2011
    Location
    El Centro, CA
    Posts
    22
    Thanks Thanks Given
    Thanked in
    Thank you very much for the info, I will have to get the rebuild kit. The hood latch left a nasty bump on my cousins head, and I just know I will do it someday soon. Those Youtube videos are a good find. I am going to watch them right now, if I can, I will get my dad to take photos. How To's are priceless sometimes.
    EDIT: Jody said Stromberg <span style="font-weight: bold">165</span>, and PC said <span style="font-weight: bold">175</span>. I just want to clarify here, I am not used to these carbs.
    &quot;73 Jensen Healey - &quot;64 Impala - E85 powered &quot;03 nSRT-4
  6. #26
    Obi Wan PC's Avatar
    Join Date
    Jun 2003
    Location
    SoCal
    Posts
    2,289
    Thanks Thanks Given
    2
    Thanked in
    Well, mine say 175 on top.
    And my old copy of the Haynes Zenith Stromberg CD Carburetor Workshop Manual only references types 125, 150 and 175.
    pc.
  7. #27
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    I was incorrect in my post. I believe I either fat fingered it or hadn't had enough coffee yet. 175 is correct.
  8. #28
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    Oh, and stupid trick for the hood latch. Get some hot water pipe insulation. The round foam stuff with a slit in it for fitting over pipes. Slip a length of that over the latch and put a little tape on it to hold it in place. It's a noggin saver.
  9. #29
    Join Date
    May 2011
    Location
    El Centro, CA
    Posts
    22
    Thanks Thanks Given
    Thanked in
    Does anyone have any advice for getting the bottom bolts off the carbs? The front one seems impossible to access. I heated and bent a wrench in effort to get it, but still have no room to rotate. (It was a crappy wrench, not my Craftsman)I am fearing I might have to take the IM off.
  10. #30
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    A stubby or cut down open end wrenchand a lot of patience. It's only slightly less annoying with the manifold removed.
  11. #31
    Obi Wan PC's Avatar
    Join Date
    Jun 2003
    Location
    SoCal
    Posts
    2,289
    Thanks Thanks Given
    2
    Thanked in
    OBTW:
    Since we're talking about fasteners, there's something the new, not used to oddball Euro-car, JH owner may not be familiar with. (I'm not saying you specifically are or aren't, just that most new JH owners aren't. (I wasn't until I bought my car.))
    Most of the screws on a JH aren't Phillips. They're Pozidriv.
    So any new JH owner needs to have a good set of Pozidive screwdrivers and insert bits handy.
    And unfortunately, since many JH's have been owned by and worked on by people who didn't know, they tend to have mangled screw heads.
    pc
  12. #32
    Join Date
    May 2011
    Location
    El Centro, CA
    Posts
    22
    Thanks Thanks Given
    Thanked in
    PC, thank you for the info. I was unaware of the Pozidriv screws. I will try to find a quality set online, as I assume Autozone wouldn't have them. I did read an article about these Thackery washers being smashed, which mine are.
    I wanted to give you guys an update, so you didn't think I was not paying attention to the car or forums. I was on annual leave and my dad had a heart attack. He is doing fine now, and was released from the hospital after a day. In leiu of this, we haven't made any progress on the Jensen. He has the fuel tank and is going to see if he can get it repaired. He is going to remove the carbs and send them to me so I can rebuild them. When I get them, I will make a detailed thread on the rebuild. I can not find one, and I know someday it will help someone out. It will be a good learning experience, as all I know right now is my 4bbl Edelbrock on my Impala.
  13. #33
    Yoda JamesWilson's Avatar
    Join Date
    Mar 2002
    Location
    Glasgow, Scotland, UK
    Posts
    4,858
    Thanks Thanks Given
    Thanked in
    My fuel tank was rusted out on the bottom too. The previous owner had "fixed" it byt fiberglassing over the rotten areas. I obtained another tank from a friend but foud that it too had the same problems with rust.
    I had it repaired at a local radiator shop, who cut out the bad bottom section and welded in new metal. Note it had been years since any fuel had been in the tank and it was safe to weld.
    New on left, all shiny and black, old on right with fiberglass mat showing...
    I'll admit the fiberglass worked, at least for a couple of years... but I'm happier with it properly welded.
    I'll mount the new tank on non-porous material with a slight air gap underneath.
    <span style="font-weight: bold">Healey Journal</span>
    Just 5 years into a 2 year project....
    1967 Austin Healey 3000, 1972 Jensen-Healey, 1962 Rochdale Olympic
  14. #34
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    A lot of folks use strips of rubber with gaps in between to allow air passage.
  15. #35
    Join Date
    May 2011
    Location
    El Centro, CA
    Posts
    22
    Thanks Thanks Given
    Thanked in
    Not a bad idea. My dad is going to call a local shop to see if they will repair it. I have a few fiberglass spots in my floor boards in my Impala. Fixing them is not exactly first on my list of things to do. When I got it I didn't know the gas tank had a hole, until I went to the gas station. It was a bad day to be me LOL. He is going to take the carbs off next week hopefully.
  16. #36
    Join Date
    Dec 2011
    Location
    Austin, TX
    Posts
    1
    Thanks Thanks Given
    Thanked in
    Hi, don't know if you're still working on the carbs but the most detailed explanation of the function and overhaul of the Stromberg 175CD I've seen online is on the Buckeye Triumphs site:
    http://www.buckeyetriumphs.org/techn...bsI/CarbsI.htm
    As for the hood height, the original support is long gone on my 73 JH so I use a broomstick. Not elegant but it raises the hood waayyy high enough!
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
