Results 1 to 12 of 12
Thread: ZS carb on 1980 Spitfire
Discussions of Triumph motor cars
  1. #1
    Join Date
    Nov 2010
    Location
    Rutland, VT
    Posts
    57
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi,
    Ok now that winter is over in the Northeast, I am getting the car on the road. I bought this in Oct 2010 and have been getting to know it through the winter.
    I have noticed an issue with carb. I did take it apart clean and new gaskets. It does have a funky manual choke that doesn't work and looks like a replacement/homemade job. The issue I have is that the piston gets stuck all the time. Prior to starting I remove the air filter and can not budge the piston with my finger. I have to take a screwdriver and pop it up to get it to move freely.
    Is it possible to be out of round somehow? What to do?
    BTW, the Home CFO has given approval to purchase a new carb if needed. I was contemplating a Weber DGV.
  2. #2
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,234
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: ZS carb on 1980 Spitfire
    Any pictures of the parts in question?
  3. #3
    Jedi Trainee SkinnedKnuckles's Avatar
    Join Date
    Jan 2005
    Location
    Cordova, TN
    Posts
    387
    Thanks Thanks Given
    Thanked in
    The carb top cover may not be oriented correctly which could bind the air valve. There are a couple of alignment "bars" on the top & bottom part. I think the writing on the cover is oriented across the car as if to be read from the cockpit.
    Also, the top cover needs to be tightened in a sequence and not just cranked down around.
    Brent
    '73 TR6
    The harder it is to reach the drop light the more likely it is to shine in your eyes.
  4. #4
    Join Date
    Nov 2010
    Location
    Rutland, VT
    Posts
    57
    Thanks Thanks Given
    Thanked in
    ok, here are pics.
    Photobucket Triumph Carb
  5. #5
    Join Date
    Nov 2010
    Location
    Rutland, VT
    Posts
    57
    Thanks Thanks Given
    Thanked in
    Oh BTW I did tighten in a sequence. I did it small tighten adjustments at a time, moving in a star pattern.
  6. #6
    Join Date
    Jan 2005
    Location
    Cordova, TN
    Posts
    387
    Thanks Thanks Given
    Thanked in
    Well, a try, anyway. I don't see how the choke spring could be causing the problem, though, as the AV kinda floats on the mixing chamber pressure. You're not running real lean and having the air valve drive the needle into the jet on deceleration? Just guessing...
    Brent
    '73 TR6
  7. #7
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,592
    Thanks Thanks Given
    2
    Thanked in
    Unscrew the damper piston (white knob) and remove it from the damper well, then see if the air valve still sticks.
    Also from looking at the pictures, the carb and the manifold's mounting flange doesn't seem to be a match; not that it would make your air valve stick,..nevertheless..
    DRIVE 'EM IF YOU GOT 'EM
  8. #8
    Join Date
    Nov 2010
    Location
    Rutland, VT
    Posts
    57
    Thanks Thanks Given
    Thanked in
    poolboy,
    thanks I will try that and report back. I thought that was a mis-match on the carb and manifold flange. I wonder if this had a different carb that was removed.
    skiined - no, the problem is that after the car sits for awhile, like overnight, I can not move the air valve with my finger. I have to lever it free with a screwdriver, then it will move freely.
    Could it be a carb that was put together from several and clearances are not in tolerance?
  9. #9
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,592
    Thanks Thanks Given
    2
    Thanked in
    The shaft with the damper piston may be tilted in the well, putting a bind on the air valve, But as soon as you remove the damper piston as I sugested, you'll know.
    OR, might be a bit of corrosion that needs cleaning. About the only way to tell is disassembly and test fitting components until you uncover the culprit.
  10. #10
    Yoda swift6's Avatar
    Join Date
    Jul 2005
    Location
    Fort Collins, Colorado USA
    Posts
    4,126
    Thanks Thanks Given
    Thanked in
    ZS carbs are much more forgiving of tolerances than SU's, especially when it comes to the air piston as it uses the rubber diaphragm and not a close tolerance fit between the airvalve and the bell. If the damper piston is ok, you might also check the height of the jet and or how far out (down) the needle is. The widest part of the needle near its base, could be sticking in the jet.
    Shawn
    TR8FHC-Melted
  11. #11
    Jedi Trainee TonyPanchot's Avatar
    Join Date
    Dec 2008
    Location
    Where the man sends me ( MO ) currently
    Posts
    318
    Thanks Thanks Given
    Thanked in
    I did notice that you have partial blockage from the air cleaner back plate (after market) remove that bit of metal for the top vent and make sure that the side holes are open as well, looking at your second photo bucket pic.
    1968 TR 250
    1972 MkIV 1500
    1973 MKIV 1500
    2002 BMW Z-3 M
    2004 Lotus Esprit
    2007 SL 550
    2009 LR3
  12. #12
    Member
    Join Date
    Mar 2006
    Location
    Miami,Florida
    Posts
    37
    Thanks Thanks Given
    Thanked in
    Mine does the same if it has been sitting a long while (3-6 months). Usually a squirt of WD40 and working it a bit and it comes free. It is caused by old gas gumming up the works. I also drop the bowl and clean the inside. Don't forget to clean the inlet float valve.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
