TR6 TR6 gas line leak - please help
ichthos
There is one problem standing before me driving my TR6 for what is left of the summer - a leaking gas line. I hope someone can help. The pipe that connects the carbs to the fuel pump will not seal at the fuel pump end. I went and bought a new 1/4" compression sleeve at the local hardware to see if that would work, but no matter how tight I get it, when I pull the gas pump lever, I can see fuel squirting out between the fitting and pipe. Can someone offer some suggestions on what I am doing wrong?
Kevin
I
ichthos
Well, that makes me feel a little better. Are you saying that the big three do not sell the correct sleeves either? I will try you tip and see what happens. Thanks as always Randall.
Kevin
TR3driver
Great Pumpkin - R.I.P
I have not checked recently, but that was the case when I went through this problem myself.
I took a different approach : actually made a new nut for the fuel line. Fun lathe project, but of course not for everyone.
JohnnyMead
A section of fuel line I bought from Moss had what looked to be the correct fitting. That fitting worked where my store-bought fitting had leaked.
Don't know if Moss sells the fittings without the line.
John
poolboy
This fitting will work. I believe I got it a NAPA.
M_Pied_Lourd
FWIW,
I just swapped out my fuel pump 2 weeks ago and whent to my local auto parts store and bought 1/4 inch compression fittings off the shelf. I also bought new tubing nuts at the same time. I had no issues with the lines leaking on either side of the pump with the new fittings fitted.
I know that there are a couple of different quality fuel pumps out there for the 6. The one that I replaced was from Taiwan (Cheap) and the tubing nuts definately set alot deeper into the pump. I bought a better quality one (Italian) that is alot heavier and cast more stoutly than the Taiwan pump. I found that the tubing nuts seated less deeply in the Italian pump and tightened up better.
Is it possible that you might have a cracked housing on your pump?
Cheers,
M. Pied Lourd
I
ichthos
The good news is that the method Randall mentioned worked. The bad news is that when I got the pipe sealed with the compression fitting, I found that it leaked between the fitting and pump body. I finally pulled the fuel pump and found I messed up the threads. I ran a tap through it to clean it out, but I am not sure if it will be tight engough to seal now. I could use Loctite, but don't know if it will do the job. I do have a used second fuel pump. I have no idea if it works or not. I don't know how easy it would be, but another option would be to swap that part of the fuel pump with mine. Suggestions?
Kevin
TR3driver
The threads are not supposed to seal for that fitting; all the sealing should take place between the sleeve, tube and body/nut. So as long as you didn't mess up the tapered seat in the casting, it should seal OK once the threads are cleaned up.
Loctite won't help, IMO, unless you switch to tapered threads. Somewhere, I've got a pump where the DPO forced a fitting with pipe threads into the pump body and got it to seal. Not sure if he ran a pipe tap in first or not. But I would definitely pursue getting the original fitting to work, before taking such a radical step.
DNK
Kevin, you gonna take one of the LBC's to Portland?
I
ichthos
Besides the TR6, I have been in Bugeye pergatory all summer. I was sure it would be up and running by the end of July. Every time I think I am almost done, I find another problem. If I finish the Bugeye, I will be there. If not, I will probably be working on Bugeye instead. Will you be there? Are you going to be driving either one of your cars?
Kevin
DNK
Hopefully the Wedge, weather looks good so far
Platinum
DO IT, Don!!! :laugh:
kbatl
This helped me 8 years later...gotta love the forums. Thanks to all those that posted their experiance and solutions!!
poolboy
I used a dremel tool and cut off a couple of threads. That makes up for the smaller sleeve.Fuel Pump Modification 001.jpg
tomshobby
Tush,
I had an Italian pump with a staked pivot pin. Eventually the pin worked through the staking and the pin was lost along the road. I then fitted a chain clevis pin while the pump was still on the car. That worked well until I replaced the pump some time later. I did find it much easier to remove the bolts holding the pump in place if the pin was removed first.
Tom
BierRunner TR6 TR6 Gas Pedal Triumph 4
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
BobbyD TR6 TR6 Custom Aluminum Gas Tank ~ 15 Gallons Triumph 1
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
I TR6 75 TR6 rubber gas lines Triumph 6
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
hondo402000 TR6 Paint continues now the TR6 gas tank Triumph 9
B TR6 TR6 gas gauge stopped working Triumph 10
R TR6 TR6 Gas Tank Outlet Gas Tank to Body Seal Donut Triumph 6
I TR6 TR6 gas cap help Triumph 2
TR6oldtimer TR6 Central Coast Calif gas and ping in a TR6 Triumph 2
mrv8q TR6 TR6 gas tank removal Triumph 13
I TR6 69 TR6 gas tank/emissions Triumph 10
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
B TR6 Draining gas tank and lines TR6 Triumph 3
I TR6 TR6 gas gauge not reading correctly Triumph 11
Paulus TR6 Gas cap fitting on TR6 [71] Triumph 8
bobh TR6 TR6 Gas Pedal Shaft Bushing Install Triumph 16
teeslounge TR6 TR6 Sputter and Gas Triumph 8
S TR6 What were the manufacturer's estimates on gas mileage for a TR6 Triumph 4
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
