AC fuel pump rebuild kit suppliers
71MKIV
I can't find the posting where this was discussed. Does anybody have the list of parts suppliers for the AC mechanical fuel pumps?
The one on my Spitfire leaks.
Gliderman8
Steve-
I think this is the place that Paul has reccommended.
Then & Now Automotive
447 Washington St
Weymouth, MA 02188
(781) 335-8860
billspit
Somebody posted a link to a vendor that sold kits and or would rebuild yours if you sent it in. It thought I had it bookmarked, but don't see it.
71MKIV
This guy offered to rebuild mine
https://www.classicpreservation.com/index.html
dunno if that's the one you are thinking of.
I'd rather keep mine in hand and do it myself though.
I just remember somebody giving a ringing endorsement on one of these threads about a supplier for these things, didn't need it then, so of course I didn't pay much attention. I need it now, so of course I can't find it. Murphy strikes again.
RedTR3
TR3driver
Great Pumpkin - R.I.P
Dunno if they have them for your car, but I was very pleased with the kit from TRF for my TR3. It included the shaft seal that is missing from most kits, a brass screen (not plastic as some others), and both cork & nitrile rubber sediment bowl gaskets (cork is as original, nitrile works better).
Took me longer to R&R the pump than to install the kit (but I didn't try to polish the pump or anything).
Brosky
Then and Now is the favorite of mine. Although I have heard, as Randall says that TRF has improved their kits. I wonder where they may be getting them?
TR3driver
Certainly looked to me as though they were 'kitting' the parts themselves. Just the usual stapled plastic bag with a TRF label, with the loose components inside (although some of them were in smaller paper envelopes).
A definite contrast to years ago, when I got a kit in an AC box (and no shaft seal inside).
71MKIV
Well....
new pump is around 40 bucks from Rock Auto/SpitBits, 80 bucks for either Then and Now or Classic Preservation to rebuild the one I have now.
Methinks I will order a replacement, meanwhile do some due dilligence and see what I can do to fix the leak in the top cover of the one I have.
billspit
I would rather have a rebuilt OEM pump than an aftermarket one. I haven't been impressed with the pumps available for a Spitfire.
And I'm pretty sure Then and Now is the vendor I was thinking of.
Platinum
I'm in agreement with ya, Bill, regarding the "new" pumps.
I'd be checking with NAPA for a kit, too. Those AC pumps were near ubiquitous for decades, not very different internally across a number of applications.
71MKIV
No garuntee that the one that's on the car is anything close to original either. But my neighbor is a manager at the local NAPA
I'll check with him.
Got_All_4 TR6 Fuel pump rebuild, Part not included Triumph 4
D TR6 2 Fuel pump rebuild questions Triumph 6
D TR4/4A which fuel pump rebuild kit to use Triumph 7
PeterK Fuel pump rebuild Triumph 7
T Fuel pump rebuild kits - good results? Triumph 5
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
T Post-War Other Brosky, can you rebuild the TRF Italian fuel pump? Triumph 17
R Rebuild of LCS SU Fuel Pump Austin Healey 13
DenverMGB SU Fuel Pump ReBuild MG 30
HAN8L1965 65 FUEL PUMP REBUILD? Spridgets 11
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
M TR4/4A TR4 Fuel Pump Rebuild Triumph 3
W Mechanical Fuel Pump Rebuild Spridgets 1
martx-5 TR2/3/3A TR3 Fuel Pump...Rebuild or New Triumph 6
S TR2/3/3A TR3 fuel pump rebuild Triumph 10
AndreL TR6 Conversion to electric fuel pump Triumph 0
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
