1275 firing order- help needed for 1st start!
Westfield_XI
I am about to start my 11 project for the 1st time, but I have forgotten the firing order. I don't have my manual handy, can anyone help out?
Westfield_XI
Westfield_XI
Thanks, and under 10 minutes for a response!!
RickB
remember, that's counter clockwise...
(don't ask)
Westfield_XI
Westfield_XI
Not needed: I am running a MegaJolt system......
jvandyke
and? does it live?
Westfield_XI
Westfield_XI
Oh, yes... it started right-up after about 1/2 a revolution of the crank in EDIS limp home mode. The carbs and their linkages are all out of wack and it didn't idle well, but it ran long enough to turn on the fan. I have an oil leak on the right side that I can't figure out though.
There is a threaded hole of about 3/8" diameter just behind the rearmost freeze plug and just under the oil fitting that goes to the remote filter that is leaking. Is this a vent or a port for oil temp or pressure? There is a port on the adaptor I installed where the oil filter used to be that I am using for oil pressure and I have a temp plug in the Speedwell oil pan. I left my manual in Tucson and I am in LA with the car.
I still have to wire up the gauges so I don't want to run it again until I do, that will be on Tuesday after the UPS delivery brings some parts.
dklawson
That position just about fully describes the point where an oil pressure gauge would normally connect to. I guess some filter heads may have pressure taps also, but the one you're describing is the standard one on the block. If you don't want to use it... it should be 1/8 BSP but I think you'll find a 1/8 NPT plug with some Teflon tape will seal it just fine.
Yep, sounds the stock pressure port, I'm guessing you must be picking up oil pressure up exterior of the engine, at the remote filter housing perhaps. It should have shot off like a cannon with oil if it were open.
I just got some parts for a fella who has just got a Westfiled 11 kit, cool cars.
Westfield_XI
Westfield_XI
Thanks, that's what I was hoping. I will get a plug tomorrow, my pressure signal comes from the filter adaptor, so I have no need of that one. I have all electric gauges and while it keeps fluids out of the cockpit it makes wiring the dashboard more complex. I am going to get the electrics completed in the next few days, close up the scuttle of the car and move on to tuning and adjusting everything to make it drivable.
Just a reminder of why I have been hanging about this forum for the past few years: my soon to be completed Westfield project contains much of a 1967 Sprite I bought for $300. In fact the engine block, crank, carbs, rear axle with brakes and front suspension uprights all came from the original donor. As well as the motor mounts, pedal box assembly with clutch and brake cylinders and two out of four wire wheel hubs. It had a nice fiberglass hardtop which I sold as well as the old rib case transmission, the windshield and some other parts. No one wanted the body (surface rust only) so I rented a small dumpster and cut it up with a sawzall in about an hour and a half. Anyway it still lives on as a bit racier of a car.
TulsaFred 1275 firing order and plug wire arrangement Spridgets 6
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
