Results 1 to 10 of 10
Thread: 1275 firing order- help needed for 1st start!
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Warrior Westfield_XI's Avatar
    Join Date
    Oct 2006
    Location
    Woodland Hills, CA
    Posts
    541
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I am about to start my 11 project for the 1st time, but I have forgotten the firing order. I don't have my manual handy, can anyone help out?
    Westfield XI Lotus replica
    2008 Infiniti Ex35
    1984 Laverda RGS1000
    1 smart Cabriolet
    2000 F250 SD crew cab diesel
    These are only 10 kinds of people: those who understand binary systems and those who don't.
  2. #2
    Senior Member Colin8's Avatar
    Join Date
    Sep 2009
    Location
    Phoenix, AZ, USA
    Posts
    85
    Thanks Thanks Given
    Thanked in
    Re: 1275 firing order- help needed for 1st start!
    1342
  3. #3
    Join Date
    Oct 2006
    Location
    Woodland Hills, CA
    Posts
    541
    Thanks Thanks Given
    Thanked in
    Thanks, and under 10 minutes for a response!!
    2008 Infiniti Ex35
    1 smart Cabriolet
  4. #4
    Yoda RickB's Avatar
    Join Date
    Mar 2007
    Location
    Snoqualmie, WA USA
    Posts
    5,180
    Thanks Thanks Given
    Thanked in
    remember, that's counter clockwise...
    (don't ask)
    '80 MGB roadster - pageant blue with Overdrive
    '73 RWA car + rust free tub and parts - going to build an Arkley SS!
    '78 Midget - Datsun A15 with HIF4's Dogleg 5 Speed Bugeye Bonnet with Heated Miata Seats
    '80 Datsun 210 w/60 series 5 speed
  5. #5
    Join Date
    Oct 2006
    Location
    Woodland Hills, CA
    Posts
    541
    Thanks Thanks Given
    Thanked in
    Not needed: I am running a MegaJolt system......
    2008 Infiniti Ex35
    1 smart Cabriolet
  6. #6
    Luke Skywalker jvandyke's Avatar
    Join Date
    Dec 2006
    Location
    Hudsonville, Michigan, USA
    Posts
    1,874
    Thanks Thanks Given
    Thanked in
    and? does it live?
    1963 Midget 10CG Tartan Red, wire wheels, Crane Cams XR700, electric fan, HS2s, Monza exhaust, Pacesetter header, crappy paint job. Jeff
  7. #7
    Join Date
    Oct 2006
    Location
    Woodland Hills, CA
    Posts
    541
    Thanks Thanks Given
    Thanked in
    Oh, yes... it started right-up after about 1/2 a revolution of the crank in EDIS limp home mode. The carbs and their linkages are all out of wack and it didn't idle well, but it ran long enough to turn on the fan. I have an oil leak on the right side that I can't figure out though.
    There is a threaded hole of about 3/8" diameter just behind the rearmost freeze plug and just under the oil fitting that goes to the remote filter that is leaking. Is this a vent or a port for oil temp or pressure? There is a port on the adaptor I installed where the oil filter used to be that I am using for oil pressure and I have a temp plug in the Speedwell oil pan. I left my manual in Tucson and I am in LA with the car.
    I still have to wire up the gauges so I don't want to run it again until I do, that will be on Tuesday after the UPS delivery brings some parts.
    2008 Infiniti Ex35
    1 smart Cabriolet
  8. #8
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    5,719
    Thanks Thanks Given
    4
    Thanked in
    Quote Originally Posted by Westfield_XI
    That position just about fully describes the point where an oil pressure gauge would normally connect to. I guess some filter heads may have pressure taps also, but the one you're describing is the standard one on the block. If you don't want to use it... it should be 1/8 BSP but I think you'll find a 1/8 NPT plug with some Teflon tape will seal it just fine.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  9. #9
    Yoda Hap Waldrop's Avatar
    Join Date
    Jun 2002
    Location
    Greenville, SC
    Posts
    3,780
    Thanks Thanks Given
    Thanked in
    Yep, sounds the stock pressure port, I'm guessing you must be picking up oil pressure up exterior of the engine, at the remote filter housing perhaps. It should have shot off like a cannon with oil if it were open.
    I just got some parts for a fella who has just got a Westfiled 11 kit, cool cars.
    Acme Speed Shop - Hap Waldrop (864) 370-3000 www.acmespeedshop.com
    MG-Triumph Performance Engines, heads, SU carbs, engine rebuild kits, and more
  10. #10
    Join Date
    Oct 2006
    Location
    Woodland Hills, CA
    Posts
    541
    Thanks Thanks Given
    Thanked in
    Thanks, that's what I was hoping. I will get a plug tomorrow, my pressure signal comes from the filter adaptor, so I have no need of that one. I have all electric gauges and while it keeps fluids out of the cockpit it makes wiring the dashboard more complex. I am going to get the electrics completed in the next few days, close up the scuttle of the car and move on to tuning and adjusting everything to make it drivable.
    Just a reminder of why I have been hanging about this forum for the past few years: my soon to be completed Westfield project contains much of a 1967 Sprite I bought for $300. In fact the engine block, crank, carbs, rear axle with brakes and front suspension uprights all came from the original donor. As well as the motor mounts, pedal box assembly with clutch and brake cylinders and two out of four wire wheel hubs. It had a nice fiberglass hardtop which I sold as well as the old rib case transmission, the windshield and some other parts. No one wanted the body (surface rust only) so I rented a small dumpster and cut it up with a sawzall in about an hour and a half. Anyway it still lives on as a bit racier of a car.
    2008 Infiniti Ex35
    1 smart Cabriolet
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
