86 XJS v12 fuel pump problem -Help!
jehiatt
1.The local auto parts and local library have no manuals.
2.My golf buddy changed his trans filter and now the car will not fire up. The fuel pump in not working. As I am the first responder for rides and repair help I need some info before I go over there with my volt meter and try to assist in this hot weather.
3. He jacked the whole passenger side up to get at the trans pan. When it came down the problem was there.
4.The cutoff in the door operates the red relay on the right fender well.
5. He has two fuse panels but declared that access and identification is difficult.
6. Went over there anyway and fuel pump relay in trunk is not pulling on, no voltage is on any incoming leads. Fuel pump will operate with 12v applied.
7. I could use a rundown on the path of the fuel pump wiring and fuse location - or other suggestion. thanks yall
John S Farrington
The cutoff in the door is a collision sensor and will turn off the fuel pump via relays. The collision sensor can be reset by the push-in switch. If reset does not work, you need a schematic of the fuel pump circuitry that uses, more that one relay, most of which are found on the passengers side of the engine compartment near the firewall. I recommend a Haynes manual with schematic that is reasonable in price and available.
wilde_knight
I had a similar problem with my 88 xjs the problem was within the main relay. my fuel pump, nor the ecu were getting power. hope this helps.
J
jehiatt
Until we get a manual we have to hunt the hard way. Where is this "main" relay. I have one on the very front right -inside fender wall that comes on with the key and will go on and off by operating the reset switch on the drivers door jamb area. Somewhere there has to be a fused 12v supply feeding the contacts also.
John S Farrington
All built in (non inline) fuses have their function labled on the fuse box cover diagram. The positions for the fuse boxes and covers are on the passenger and driver side under dash (scuttle) panels. If you dont have these lids on the under scuttle you are in bad shape because they vary from year to year. If I were you I would have a manual of some sort (Haynes, etc.,) over nighted. The car is too complicated to play a guessing game.
J
jehiatt
Well i did find out the ECU controls the fuel pump relay. I did order a cd manual. meanwhile the boy is stranded.The car handbook is on hand and fuse locations are well marked but nothing said about one that supplies the pump relay +12v.
So in a few days I guess we will have the electrical "roadmap" to find our way home .tks yall.
J
jehiatt
So I got the CD manual ver 1.2. and it's missing vol 4 pages 125 & 126 which are likely the fuel pump wiring circuits in full color. It's also missing the pages 139 and up that are indexes and diagrams for several year vehicles.
The 1980 & 1983 diagrams that were on there are inferior quality and unuseable. The 1987% diagram was totally trash.
So - Back to square one.
J
jehiatt
Ok - I returned the CD manual. Ya'll ain't been too helpful either. It's not my car and if my Buddy can get it running again I think he will dump it fast. I would love to own and drive it, but after unsucessfully trying to help him get it going again ? No way - I think I will stick to GM type vehicles myself.
John S Farrington
Make me an offer that I cant refuse to buy the XJS in present non-running condition. Where in GA are you located?
J
jehiatt
Dear Jack:
Tain't mine. Too late for best buy - besides - you have enough already.
AND:
I must apologize to all concerned - for one critical fact of this case was not known and thus not presented in my original inquisition. The unspecified piece of evidence was: that in addition to the right side of the vehicle being jacked up to change the trans gasket - the JAG would not crank afterwards because there was a battery problem.
The battery was too weak or bad and would not turn the engine over - so another battery was placed in the boot to do the job. It turned the engine over but the engine would not fire up.
Have you figgered it out now?
In the boot there were two brown wires in the battery compartment area - about a #10 and a #12 wire, with female spade lug connectors on them. The owner said that according to the owners manual those were the caravan connectors. From then on they were dismissed as relevant to our problem.
So last week I go over there again and look at this car some more and here is the battery sittin out in the boot and there is this small black plastic "bump" halfway back on the positive cable. Inside the "bump" are two male spade lug connectors. They look like they might hook up with the brown wire female spade connectors but the female connectors can't reach. They would reach if the battery is in the battery box and not in the boot. So we put the battery in the battery box, hook up the two brown wires, and the JAg fires up.
Recap;
So, when my buddy removed the battery from the battery box and placed it in the boot area to change it out - he also must have pulled the wires out of that connector - and didn't notice it or what ever. He never mentioned a battery problem until last week.
I could not see a fuse holder or such on those two brown wires in the trunk feeding the fuel pump and what ever else. Without the diagrams I have no clue but I think I would cut and add a ATC 30A fuse holder on those wires just for luck.
D 1991 xjs v12 ,smell of fuel. Jaguar 4
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
W new shocks for jag xjs v12 ? Jaguar 3
Wray XJS Coupe V12 Jaguar 11
D xjs v12 tire wear Jaguar 1
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
D 1991 xjs v12 strange pipe Jaguar 1
D grinding noise on 91 xjs v12 Jaguar 5
D 1991 xjs v12 high idle speed. Jaguar 8
T Erratic idling v12 xjs Jaguar 2
Sergio MGA MGA 60 ROADSTER WITH BIG HEART JAG XJS V12 MG 6
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
M XJS V12 Cruise Control Jaguar 3
R XJS V12 Problem Jaguar 5
JPSmit Jag XJS convertible Spotted 0
D 1992 jaguar xjs abs Jaguar 1
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P XJS Jaguar 20
M For Sale For sale - xjs parts Jaguar Classifieds 0
JodyFKerr Tempted by an '88 XJS Jaguar 9
Steve P. carbs for XJS V-12 ? Jaguar 2
Steve P. Newbie with XJS...opinions wanted Racing 9
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
M Replace V-12 90 XJS Air Cond Expansion Valve Jaguar 7
CZ_Dave 1990 Jag XJS Jaguar 1
B 86 xjs trans dipstick Jaguar 0
M 1990 XJS Catalytic Converters Jaguar 5
H 1988 xjs battery condition indicator ? Jaguar 8
T OT - vintage XJS hill climb video Triumph 0
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D 1988 xjs--no start Jaguar 2
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
tony barnhill 1995 XJS Convertible Jaguar 10
T 1990 xjs conv -" A "brace Jaguar 2
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
V '90 XJS waist molding question Jaguar 3
X Oil For My XJS Jaguar 7
boeingpilot Someone help me buy an XJS! Jaguar 10
jackq Found an 88 XJS V-12 locally. Jaguar 11
M 90 XJS Antilock Brakes Question Jaguar 2
beachbumbarry XJS Vehicle maintenance Jaguar 7
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
M Jaguar XJS factory alarm system. Jaguar 14
X XJS Manual Gearbox Kit. Jaguar 1
M Manual Transmission Kits for V-12 XJS Cars Jaguar 3
D facelift xjs coupe speeakers Jaguar 0
