Ball Joints and mushy rubber
Tabcon
What is it with the rubber boots used on the Triumph front suspension ball joints? The ball joints on my car can be no more than 2 or 3 years old and they're already starting to fall apart. You can literally pull the rubber apart with your hands.
This is on a car that never sees any type of weather and is not exposed to road salts, sand or even dirt.
Is there a certain type of lubricant that causes them to get mushy? If so, is there also one that doesn't do this?
Tab
TR4nut
Tab-
Unfortunately, you've found a common ailment that has hit others - due to vendor issues with the available part suppliers. Not sure what the perfect cure is other than experimenting with the vendors to see whose parts holds up.
Randy
TR3driver
Great Pumpkin - R.I.P
I think it's just a crap shoot. I've installed boots bought at the same time from the same vendor, on the same car with the same lubricant; and had one fall apart within months while the other lasted for years. Poor quality control at some point in the manufacturing process, is my guess.
Seems like I've had better luck with the boots from TRF, but that could be just chance. I robbed the tie rods & center link from TS39781LO the other day, and most of the boots were good enough to reuse. They've been on there since before VTR 2000 (and came from TRF IIRC). Ball joint boots look good too (but I didn't need them).
DougF
This isn't the answer, but I made a temporary repair on a new, holed boot with black RTV about five years ago. Much to my surprise, it is still holding strong.
Poor quality rubber products have long been a topic of rants by many LBC owners.
Tabcon
Tabcon
Do you guys think it's the lubricant that does this?
It's almost as if the lube attacks the rubber, if that's what they're using, but I bet it's some type of compounded goo.
When I install new ball joints, I may try a different type of lubricant, maybe a Teflon or something on one of them just to see what happens.
Don Elliott
The rubber boots on the ball joints and tie rod ends got mushy, sticky and got cuts in them about 3 years ago after only about 2 or 3 years in place. I only drive in the summer and mostly in good weather. I had been using black all-purpose grease for ball joints, etc. So I bought new boots for all of these and changed them 2 years ago. At that time I decided that it might have been the rubber, but it might also be the grease - or maybe a combination of both. So I have been using red Amsoil synthetic grease for these last two years (8,000 miles) and the boots still look great. I plan to give it a longer test, so I'll be able to tell you the results of this experiment in about another 5 or 10 years.
jjw
This is a problem I've experienced with rubber parts for years (on LBCs)... boots, seals, etc... These days, much if the stuff is sourced from Mom-and-Pop outfits in India, China, and the like... where there is absolutely no quality control when it comes to materials. There are no longer any "factory" supplier engineers qualifying the vendor base. The best you can do is buy from one of the better parts suppliers (TRF, Moss, etc...) and if/when you get something that's bad, bitch about it...
D TR4/4A TR4 inner ball joints Triumph 8
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
M Broken Ball Joints Spridgets 14
King_of_England Ball Joints and Mini ID British Motor Corp 7
bigjones Ball Joints - does this look right to you? Spridgets 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
A TR6 Jag ball joints donot work on TR6!! Triumph 5
V TR6 A TR6 with Jag ball joints Triumph 27
S S-Type Bad Ball Joints, Control & A Arms Jaguar 19
KVH Tie Rods and Ball Joints Triumph 5
S Wedge Ball joints on TR7 Triumph 7
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
Joe Reed General MG MG logo ball point pens... MG 0
D TR4/4A inner tie rod ball joint tension Triumph 0
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
Keith_M steering rack inner ball joint Spridgets 14
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
D Side Rod Ball & Joint Installation Austin Healey 17
S TR2/3/3A this shifter/ ball and cup Triumph 5
W Etype lower ball joint removal Jaguar 14
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
T sourcing linkage ball/sockets Austin Healey 13
J New Ball Joint for Control Arm or use the old one? Triumph 4
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
T Help on ball joint - vertical link fit Triumph 20
doughairfield Ball joint to spindle Triumph 3
Mark_Barton Ball bearing in Float Chamber? Triumph 8
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
S TR2/3/3A tr3 ball studs Triumph 8
Tabcon New Ball Joint Install Help Needed. Triumph 2
A fuel line ball valve - are they available Triumph 4
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
J Ball joint and steering question Triumph 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
