jjbunn
New thread to follow on from my "driving on two wheels" thread. Now I am going to reattach the wheel so that I can move the car into the back yard, a matter of some 50 yards.
First, here is the reattached old stub axle. (I have a new one from Moss, but I don't want to use it yet in case the vertical link's tapered hole for it is damaged or crufty.) I ran a 1/2"-20 die down the threads, which were all chewed up. It hadn't sheared at all, so it appears the PO's nut must have indeed worked loose.
There is a circular felt pad still surrounding the axle hole.
Here's a shot from the underside. You can see the piece that has scraped along the ground - the trunnion? Comments on this?
Here's the inside of the hub. I'm concerned about the gouges around the hole rim, if you can make them out?
Same shot, but with the new bearings from the Moss bearing kit placed where I believe they go, or do I have them the wrong way up?!? (I don't find the Bentley diagram too clear.) Also, I suppose I should grease these up fully before putting them in, even if I'm only going 50 yards?
And with the new felt pad (again: correct way up?)
As usual, comments and advice most welcome! Anything you spot amiss/wrong/weird in these photos?
Thanks,
Thanks,
