TR4/4A TR4 Question: Door check strap pin
Fairview
Does anybody know what is the original part to hold the door check strap to the door jamb? Is it a small bolt, or some type of pin? Thanks, Jeff
TR4nut
Jeff-
Depends on the year of your TR4. Can't remember if you have an early one or later. Cars before CT22343 had a different checkstrap assembly (and different A-post I think). A thin looking pin was used to hold it to the jamb on the early cars (PN 612244 or 650216 maybe ).
Later models had more the TR6 style checkstrap, I believe originally that was a rivet, but people quite often use a clevis pin arrangement. I think TRF has the rivets, pn 616122. I didn't spot anyone selling the early style.
Randy
kodanja
So what do ya do when one of the metal door strap holes has broken?
do ya need to weld in a new one?
Is there a replacement part?
thats the issue with mine on the passenger side door....
TR6oldtimer
I have the same problem. The part is not listed anywhere I have looked. (Of course you could by a new door) I plan on grinding off the old one, and fabricate and weld or bolt on a new one.
A TR4/4A TR4 A wood glove box door question Triumph 0
G TR4/4A 63 TR4 Generator Question Triumph 15
KVH TR4/4A TR4 Steering--Just a Question I've Always Had Triumph 1
E TR4/4A 63 TR4 Inlet Manifold question Triumph 4
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
TR4v8 TR4/4A tr4 front suspension question Triumph 2
thechileman TR4/4A TR4 interior question... Triumph 14
J TR4/4A Odd TR4 transmission question Triumph 10
S TR4/4A Tr4 bodytub to frame question Triumph 4
TR4A_IRS TR4/4A TR4 vs. TR4A flywheel question Triumph 19
KVH TR4/4A TR4 OD Maybe Last Question Triumph 2
J TR4/4A TR4 Upgraded inlet manifold/valve cover question Triumph 42
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
T TR4/4A TR4/A cross-tube question Triumph 9
doughairfield TR4/4A Brake question on the TR4 Triumph 9
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
Stinger TR4/4A 1965 TR4 For Sale Question Triumph 9
J TR4/4A TR4 Brake question. Triumph 4
thechileman TR4/4A TR4 Stupid question Triumph 11
T TR4/4A TR4 head question Triumph 1
J TR4/4A TR4 Stromberg Carb Question ? Triumph 12
T TR4/4A Quick question on TR4 battery Triumph 7
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 / TR4 heater question Triumph 2
SCguy TR4/4A TR4 boot question Triumph 3
SCguy TR4/4A TR4 Spare tire question Triumph 5
T TR4/4A Moss TR4/5/6 front fender patch question Triumph 2
SCguy TR4/4A TR4 Head Light Wiring question Triumph 4
D TR4/4A TR4-A Electrical Question [Again] Triumph 8
D TR4/4A TR4-A Wiring Question Triumph 5
TR4nut TR4/4A Speaking of Webers - TR4 application question Triumph 38
SCguy TR4/4A TR4 Rheostat question Triumph 4
SCguy TR4/4A TR4 Wiper wiring question Triumph 7
SCguy TR4/4A TR4 parts question??? Triumph 9
SCguy TR4/4A TR4 Under the Dash Vent Question Triumph 6
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
M TR4/4A TR4 Dashboard removal question Triumph 3
J TR4/4A Amp to Volt meter wiring question TR4 Triumph 7
LastDeadLast TR4/4A Question about a TR4 Triumph 8
SCguy TR4/4A Fuel Tank, Fuel line question, TR4 Triumph 7
SCguy TR4/4A TR4 wiper question Triumph 6
A TR4/4A TR4 gear box question Triumph 4
