MGB MGB Panel Light Dimmer
kyreb1862
I saw an article once about rebuiding the panel dimmer. Would anyone happen to have a link to that particular article?
Mickey Richaud
Best way to rebuild: B-Y-P-A-S-S it! /ubbthreads/images/graemlins/wink.gif
Mickey
kyreb1862
kyreb1862
I am sure your right Mickey but I'm hard headed and think if it is on the car that it just has to work! /ubbthreads/images/graemlins/tongue.gif
Platinum
YAY JOHN!!
Yours is column mounted and easy enuff to get to, yes?. A good spraying into the unit after removal, with "CRC 2-26" or any good "plastics safe" tuner lubricant would be the first thing to try. Not sure about your particular one but it's just a potentiometer. Usually the "brush" gets mucked up and contact is sporadic or lost. Be glad you don't have the "older" unit. Requires three extra elbow joints to remove.
vping
Bronze
Ya mean like on a '67?
Platinum
Yup. Fun, innit?
kyreb1862
kyreb1862
My dimmer is mounted in the dash. It is just frozen up. I can't get the knob to turn. I'm goin to take it out and try a little lube on it and see if I can get it un stuck.
Rob_P
Hey, that's what mine does! (or doesn't do)
I was going to leave it since the dash lights work, now i can see how much fun/pain this job will be!
Good Luck. /ubbthreads/images/graemlins/smile.gif
Rob
kyreb1862
kyreb1862
[ QUOTE ]
Rob
[/ QUOTE ]
Keep watching. I'll report as I make (or don't) progress.
wam
I assume you have the dimmer control with the "resistor" circuit card (Moss P.N. 146-300). The unit in my '78 B wasn't jammed, but it had only a very small range of dimming before the lites would just shut off. The device has a metal plate riveted to a zamac body casting. Grinding or carefully chipping off the rivetting will enable removal of the plate and reveal a phenolic circuit card with a pattern of resistance foil on which the wiper blade moves in rotation to connect various diminishing resisitances into the circuit. Its possible some of this foil has been burned through and the wiper has picked it up and jumbled it into a blockage that won't allow the shaft to be turned...could also be the zamac casting corroding or deteriorating and binding the shaft...try a bit of penetrating oil from the outside. If the card does have damaged foil, it might be repaired with some judicious lite duty soldering...bridging burned out spans with a small glob of solder. Use a very active liquid soldering flux sparingly just at the desired spot to facilitate good bonding...and a magnifying glass or some sort of magnification lite or hood is helpful to see the small working area. My repaired dimmer has been working fine...under test conditions...I prefer brighter dials so don't ask the dimmer to do much dimming. From the purist's perspective, a working dimmer brings satisfaction and it can always be shown to an appreciating colleague then turned up bright for running. After repairs, prepare the two rivet bases in the body for drilling and tapping...I recall using 2-56 round head screws...or maybe the next size up. I do a lot of model rail stuff and have the small tools to do this work but they are not expensive.
Bill
kyreb1862
kyreb1862
Now for the repair work followup. After some careful application of WD40 to the shaft of the dimmer, and then a little soaktime, I took a pair of pliers, padded the jaws with a piece of an old towel and then applied pressure. A little gentle pressure and soon the dimmer knob was working. Guess I got lucky. The lights now dim and brighten like they should. Thanks for all the input guys! /ubbthreads/images/graemlins/thumbsup.gif
Mickey Richaud
Isn't it amazing that so many of the problems with our "terribly undependable" LBC's are actually minor and nearly always have simple fixes? /ubbthreads/images/graemlins/thumbsup.gif
Glad it worked out for ya!
Mickey
jlaird
A little love is required from time to time.
Platinum
I'd say still get some CRC 2-26 or equivalent "tuner lube." WD-40 is not a lubricant of any significance: "Water Displacement"...
CRC 2-26 is an elecrtronics/electrical lubricant. Plastics safe as well.
kyreb1862
kyreb1862
Thanks for that suggestion Doc. I'll hit Radio Shack this weekend and pickup some. I used to buy it there when I was fooling with model trains a lot.
Steve_S
I suggest replacing the rheostat with a push-pull switch like the one for early map lights. Then put the rheostat knob on it. You will not be able to tell the difference visually, but will have full brightness, which is all you really need since they aren't that bright to begin with. And it retains the ability to turn the lights off if you desire.
Nunyas
for driving under the cover of darkness obviously /ubbthreads/images/graemlins/grin.gif
Guinn
My PO hardwired the panel lights into the headlight circuit so if the headlights were on, the panel lights were full on. I found a convenient hole into which I installed a rheostat with an appropriate range and wired IT into the headlight circuit. Works like a charm.
Guinn
Rick_Stevens
[ QUOTE ]
Guinn
[/ QUOTE ]
/ubbthreads/images/graemlins/lol.gif Now he can REALLY dim his headlights for oncoming traffic. /ubbthreads/images/graemlins/jester.gif
R.
R MGB MGB Roadster Door Panel Speakers MG 9
B MGB MGB rocker panel replacement MG 3
jjbunn MGB-GT Interior MGB GT Panel Dimensions? MG 9
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 2
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
