TR6 Bell Stainless Exhaust System,tr6 ??
ALLAN
Who has the Bell stainless exhaust system. how is the quality, how does it sound (how loud) and where do you buy ?
Brosky
It can be loud in my opinion, but then noise is always subjective to the listener(s). Definitely not as loud as a Monza or Ansa system, but louder than stock.
Before buying, try to find a local club event and someone will surely have a set installed. At the Triumph day in Brookline, MA this past weekend, several guys asked the car several spots away from me to start up so they could hear his Bell system. Then they asked to hear my stock system with headers.
Some liked his and some liked mine. All a matter of taste and hearing the exhaust on the same car as yours for yourself is always the best way to tell BEFORE buying.
Also, make sure that you find out how old the system is. They seem to get a bit louder with age.
Ab Crevoiserat
If you are talking about the Stainless Steel system with twin pipes (one on each side) sold by Moss, I put it on my TR6 and I really like it. It is louder than the stock, but not so loud as to be intrusive. You can still play your radio at a normal level or carry on a conversation with your passenger without shouting any more than normally. If you like a deep sound then go for it. Good luck
CSFairfield
What header do you have with the exhaust system?
Gliderman8
For what it's worth, I have the dual Anza exhaust on my 6 and I like it. I'm using it with the stock header. It sounds n i c e!
By the way, welcome to the BCF!
jfarris
My 56 TR3 had one muffler and was way too loud (how can that little engine make that much noise). I solved the problem with a motorcycle muffler baffle. If you have access to a joint that will come apart, you can bolt it in. At $8, it is an easy experiment. Works great! My son has the Moss, two pipe stainless set on his TR6, it sounds great, a little louder than stock.
Good luck,
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 22
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
3798j Ex-Bell Telephone "55 Ford F100 Other Cars 8
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
R Plug bell housing/clutch housing hole? Austin Healey 10
R Drive gear Bell housing shim Austin Healey 1
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
S Bell housing to gearbox - torque spec? Austin Healey 4
B Position of dowell bolts on Healey bell housing Austin Healey 32
Tabcon Wheels-Tires-and Bell Bottoms Triumph 15
johnrip Wedge tr7 clutch bell housing bolt? Triumph 4
Scott_Hower Bell Header for 1500 engine... Spridgets 12
M Looking for a E Type Series III Bell Housing Jaguar 1
M Gasket sealer on bell housing to gear box Austin Healey 13
Dave Richards Oil at Bottom of Bell Housing Austin Healey 12
regularman Funny how timing is some times..ding the door bell Spridgets 5
C Bell in rear of XJ6 Jaguar 2
Dave Richards Bell Housing Bolt and Nut BJ8 Austin Healey 2
G SS Exhaust Systems - BELL vs. FALCON Austin Healey 13
A Bell Housing Oil Seal Mystery Spridgets 6
Howard_The_Duck Bell Exhaust System.... Any Thoughts? MG 8
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
E Moss stainless exhaust offering. Austin Healey 28
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J General Tech Stainless-steel caliper pistons Triumph 8
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
TulsaFred Polished stainless steel bumpers? Spridgets 13
S TR2/3/3A radiator pipe in stainless steel Triumph 5
T Rattling stainless muffler Austin Healey 10
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
