Rack & Pinion Conversion Healey 3000 1964
R&M
Just looking through my latest edition of Hemmings and found an ad for 64 3000Mk III with rack & pinion steering.
??Is anyone aware of an available conversion for Big Healey's??
Thanks
R&M
/ubbthreads/images/graemlins/driving.gif
Randy_Gay
I'm not aware of a commercially available conversion. It's a fairly complex project. You can check out the modified site if you want more information.
R
R&M
Thanks,
I saw the ad for the Healey in Hemmings and wondered if anyone was aware of a commecially avaible conversion as my Triumph will out handle my Healey in a heart beat with the rack & pinion. /ubbthreads/images/graemlins/driving.gif
Lin
Michael Salter (Precision Sports Car in Canada) did this conversion from an MG B. An image is attached. More info is available at Larry Varley's website https://www.acmefluid.com.au/larry/ahx12-1.html
Michael did at least think about making a conversion kit available, but I don't know if he did or not. You might want to check with him: msalter@precisionsportscar.com
Hope that helps.
Lin
1960 BT7 in restoration
1959 Bugeye
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
Not sure how you define "handling". Ability to go around corners quickly, steering responsiveness to small changes, braking ability, general perception of "feel", or what? All are part of handling. It's rather subjective & defined differently by different drivers.
If you are comparing the later model Healey to the Spitfire, the weight & size differences alone will make a huge difference in feel/handling of the two cars. The rack & pinion steering would likely make little difference in the Healey's feel, certainly minimal difference in overall handling.
The steering gear ratios, turns lock to lock, make a tremendous difference in responsiveness to small steering wheel inputs. The Spitfire likely has a faster steering ratio than the later Healeys. Early Healeys had a quicker steering ratio than the later models & combined with less weight, a different feel. Overall handling is not that much different.
Rack & pinion steering is often used on Healey V8 conversions since it has less bulk, takes up less engine compartment room, & the steering column can be easily U jointed to go around engine parts.
For all out, at the limit, driving R&P does give a little better feel, & can be more easily modified for optimum steering geometry in a competition car.
Keoke
What R & M means Dave,is when you give the Rumph a bit of handle the back end comes around quicker.--Keoke- /ubbthreads/images/graemlins/rolleyes.gif
Keoke
Yes Patton, I think so.Also, there was a young Chap up in The State of Wasington that put a Wankel Engine and a R&P in a 100 including a BJ8 wooden dash. Can't remember his name at the moment and have not heard from him in years. Test runs indicated the car was very stable and faster than a speeding bullet-no red line on that engine you know--Keoke
Dave Russell
Yoda - R.I.P
I believe I read that R&P steering was considered for the original AH 100. The designers felt that the R&P units available at the time, although cheaper, would have marginal strength for the application & so went with the other arrangement.
Keoke
Probably so Dave. However, you know DMH wanted a V8 engine so bad he could taste it but nobody would sell him one.I think perhaps the R & P thing may be in that same catagory.Contrastingly, Jensen obviously had no problem obtaining the Chrysler Hemi for their cars. Ford also sold V8 engines to other british car makers, so who knows what really went on back there other than a lot of people in the British Motoring enclave made a lot of bad decisions IMOP.--Keoke
Keoke
HI zblu, Thanks I put that one in my file.Way too much work for this young fellar though.---Keoke- /ubbthreads/images/graemlins/grin.gif
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
J Brittanicar Rack and Pinion Conversion Austin Healey 10
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
Jim_Stevens Rack and Pinion Conversion- lessons learned Triumph 5
C TR2/3/3A TR3 Rack and pinion conversion Triumph 6
bluemiata90 TR2/3/3A TR3 rack and pinion conversion /turn signals Triumph 9
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
bluemiata90 TR2/3/3A Mustang II rack and pinion conversion to TR3 Triumph 5
R TR2/3/3A TR3 rack and pinion kit problem... Triumph 10
M MGA RHD rack and pinion wanted MG 19
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Electric Powered Rack & Pinion. Triumph 4
T XK120 fit 140 rack & pinion Jaguar 3
M TR2/3/3A Identification of Rack and Pinion Unit Triumph 3
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
J TR2/3/3A Rack & Pinion warning on TR3s-- Triumph 10
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
S Anyone need a rack and pinion for a project? Other Cars 1
F Spitfire Spitfire rack n pinion lub Triumph 6
B TR4/4A TR4 to TR3A Rack & Pinion swap Triumph 4
smaceng Steering Rack Pinion Leak Spridgets 11
T T-Series Need advice re MGTF rack and pinion removal MG 4
Lin Rack and Pinion Jaguar 3
B E Type rack and pinion motion Jaguar 4
P Panther Kallista, rack and pinion woes... Other British Cars 5
L Rack and pinion for big Healey? Austin Healey 9
1 rack and pinion Spridgets 2
gubba Has anyone here used this Rack & Pinion? Triumph 8
martx-5 TR2/3/3A Last Hurdle w/TR3 Rack & Pinion Triumph 5
prb51 TR2/3/3A German TR3 Rack & Pinion kit Triumph 10
fad64b TR2/3/3A Rack and pinion TR3 Triumph 8
prb51 TR2/3/3A Ebay TR3 with rack?pinion and fan unit Triumph 1
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
T TR2/3/3A Best place to buy a rack and pinion for TR3A? Triumph 13
C TR2/3/3A TR3A Rack and Pinion and Alternator in!! Triumph 9
T Rack and pinion, oil or grease? Triumph 6
77_MG_Midget Rack & Pinion Steering question, 1500 midget Spridgets 2
A TR2/3/3A rack & pinion steering for a TR3 Triumph 5
J TR2/3/3A Rack and Pinion for a TR3 Triumph 19
philman removing nut for steering rack pinion gear Restoration & Tools 0
philman rack and pinion tool question Triumph 1
G Rack & Pinion installation MG 2
T TR6 Need a slower rack and pinion for my 69 TR6 Triumph 7
S BJ7 - Parts Needed & Rack & Pinion Inquiry Austin Healey 4
Basil Rack and Pinion? Austin Healey 4
