BN1 Windscreen Formed Rubber
zblu
Found a site in the US a couple of years ago that purported to be able to supply formed rubber for the windscreen to shroud that matched the body dip at the shroud/fender connection, never saved the site address, anybody heard of them?
Dave Russell
Yoda - R.I.P
You could enquire here:
https://macgregorukcarparts.com/
They have quite a few rubber bits. Ask them if it is curved.
If you wish, I can give instructions on how to get a perfect curved fit on the straight seal which is most generally available. It was published in the 7/04 issue of "Austin Healey Magazine" by AHCUSA.
healey106
I don't know that company, but you may want to try to contact Don Rould. He had that done a number of years ago and had copies for sale. He was located in Fullerton, CA but I believe he may have relocated to Michigan? He is a long time member of AHCUSA. I have been trying to track him down myself, but have been unsuccessful. good luck
jim /ubbthreads/images/graemlins/driving.gif
GregW
Platinum
If you do buy from MacGregor, don’t forget to mention this site. They are one of the supporting vendors here (click the vendors button at the top of any page). Basil gets a little money to help keep this forum alive. /ubbthreads/images/graemlins/driving.gif
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Dave--
If you look at the original BMC publicity and advertising shots for the 100 they all show the usual "wrinkle" in the seal--you know that I am a dog for authenticity and so I opted to install mine that way.
Nevertheless I'd be interested in that information. Martin McGregor claims that even though his seal is cut from a roll you can get a perfect flat fit if you do not slide the rubber through the frame (as I of course did) but rather push it in little by little thereby creating, I guess, the necessary curve.
Dave Russell
Yoda - R.I.P
Michael,
I sent an email with attachment. Pushing the seal in rather than sliding is part of it. The other part involves heat stretching & setting just the curved ends.
Michael Oritt
Thanks Dave--
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Healey Nut BN1 at Auction on eBay Austin Healey 4
