Results 1 to 14 of 14
Thread: SU hs4 carbs
Discussions of MG Sports Cars
  1. #1
    Join Date
    Mar 2002
    Location
    sayre, pa
    Posts
    195
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    SU hs4 carbs
    just figured i'd ask if anyone has a tip for tuning the hs4 carb for winter. ever since the weather got real cold, the b is running like crap.
    a little backfiring here and there, with the engine stalling sometimes from idle/acceleration. seems sluggish then all of a sudden will regain its power. i tried to do the mixture adjustment myself, but i kinda screwed up. i tried to turn them both the same amount, but got carried away.
    (brain freeze) how do i reset them to start all over again? also on the idle adjusting nut on the bottom of the suction chamber(dashpot), is the adjustment right for rich and left for lean or vice versa?
    what about dashpot oil? i'm using 20/50 castrol.
    is it too heavy for this weather?
    thanks guys and gals.
  2. #2
    Join Date
    Jul 2001
    Location
    Otsego Mi, USA
    Posts
    104
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    Your dash pot oil is WAY too heavy. Try auto transmission fluid, it helps keep down the deposits on the valves. And don't overfill.
  3. #3
    Jedi Hopeful Lynn Kirkpatrick's Avatar
    Join Date
    Apr 2002
    Location
    Indiana (aka paradise)
    Posts
    169
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by XJRpilot:
    <hr></blockquote>
    If you haven't done it before, adjusting the SU's is too complicated to describe here. The directins may be in the forum someplace (Basil?), or go to Google.com and search on SU carbs. I bought the doodad that used to balance the carbs at idle & it works. It was worth the $'s.
    ABOUT THE DASHPOT OIL: everything printed says 20w-50, which I have been running for the 3+ years with no fouling, should AT oil be used in the winter & 20w-50 in summer? Does it make a difference? Is AT OK all year?
  4. #4
    Join Date
    Dec 2002
    Location
    Victoria, B.C.
    Posts
    811
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    I would always say checkeverything else before your carbs!! There may have been a little water in the tank or anything!! First thing, add gasline antifreeze, second thing check points, timing and plugs!! Last thing carb settings!! GOOD LUCK BUDDY!!!
  5. #5
    Obi Wan coldplugs's Avatar
    Join Date
    Apr 2002
    Location
    Central Maine
    Posts
    2,495
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    Lynn's right re the SU's - you need a fair amount of info. The best source to start with is a shop manual.
    Re the SU damper oil - I spent a lot of time on this years ago (on a Jag) experimenting with different weights. I tried one, drove the car, sucked it out and tried another. I tried light machine oil through 40 weight and settled on 30 weight as the best (it wasn't winter, though). There wasn't much difference between them except for the very light oil. I think 20/50 is fine.
  6. #6
    Join Date
    Mar 2002
    Location
    sayre, pa
    Posts
    195
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    i have the repair manual but the directions are somewhat confusing. looking for the laymens version. as for the carb air flow meter, i can use the hose in the ear method for now. i am planning to get one after the new year. what about marvel mystery oil? the 20/50 looks awful thick in the dashpots in this cold weather.
  7. #7
    Join Date
    May 2002
    Location
    Shropshire, England, U.K.
    Posts
    2,015
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    Hello XJRpilot,
    Mixture adjustment is very easy, screw the nut down for a richer mixture, this pulls down the jet. As a ball park starting point, remove both
    dashpots and pistons\springs and screw the jets all the way up until they are flush with the bridge. Undo the adjusting nut twelve flats, that is two full turns down, you should now be near correct. (Also make sure your choke linkage is free and returns the jet full home).
    (It doesn't matter what needle you have fitted, they all have the same idle dimension, it won't run well over the rest of the range if the needles' are wrong though.)
    Check that your piston and dashpot are clean inside, and if not use a solvent cleaner to clean them. (DO NOT USE ANY SORT OF ABRASIVE, EVEN METAL POLISH). Also check that the needle is fitted with the shoulder flush with the piston lower face. Relace and carry out your balancing, (the tube method is quite acceptable), and idle speed adjustment.
    S.U.'s are really quite easy to adjust as long as a couple of basics are correct, and in my experience do not go off tune quickly.
    Alec [img]graemlins/thirsty.gif[/img]
  8. #8
    Great Pumpkin aeronca65t's Avatar
    Join Date
    Nov 2001
    Location
    Northwest NJ
    Posts
    13,882
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    I agree with Alec's explaination above for basic tuning of SUs (and he's right, they are pretty easy to deal with).
    Gary's comment about checking *everything else* is also a good idea...at least check plugs (and points, if you have them).
    If the car is slow to warm up (is it?), check thermostat....could be a *low* thermostat (160 F.), which will cause poor cold weather running.
    Re: Marvel Mystery Oil. It's mostly kerosene (a light oil). I've been runing 10W-30 or 30 weight for years with success. I went to a carb forum at the AH Encounter event in Princeton this summer; the speaker said he swears by 3-in-One oil (which is like 5 weight oil and similar to Marvel Mystery Oil or even ATF). He got a lot of grief about this, but I think this might be OK for a car that has the carb dampers checked frequently. I'll probably continue with 10W-30, since it's always one hand.
  9. #9
    Join Date
    Mar 2002
    Location
    sayre, pa
    Posts
    195
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    thanks alec and nial. i thought there should be a starting point for setting the jets. twelve flats = two full turns. its funny because my better half said a flat is probably the flat part of a bolt. not a complete turn. then she said if a bolt
    has six sides than it has six flats. i was speechless. maybe i ought to have her tune my su's. [img]images/icons/blush.gif[/img]
    as for the 30wgt oil in the dashpots, sure it isnt too thick? its awful cold around here.
    the oil looks like molasses in siberia. couldnt i go lighter for winter, than switch as the weather gets warm?
  10. #10
    Join Date
    May 2002
    Location
    Posts
    2,015
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    Hello again XJR,
    Sorry, forgot about the oil. The correct grade is S.A.E. 20, and in practice I used engine oil, 20\50 which works fine in our temperatures. I think in very cold weather a thinner oil will work fine. The oil is to dampen the (too) rapid rise of the piston when you open the throttle and stops the mixture going weak. Just play around until you feel that it runs well. Bear in mind that the underbonnet temperature will warm everything up.
    One basic I did not mention, make sure the needles are centred in their jets. This should only need doing after a rebuild, but if the jet nut has been slackened by mistake your needle can bind on the jet preventing it from going to the idle position. Take the air cleaner off and lift the piston by hand and release, it should drop down with a click onto the bridge. If it does not, then (assuming the piston is free in the dashpot) screw the adjusting nut fully up, slacken the jet clamping nut, (directly above the adjusting nut) and push down on the piston to centre the jet. Tighten the clamp nut the back off the adjusting nut two full turns and readjust the mixture. It is harder to write about than do.
    Alec
  11. #11
    Join Date
    Mar 2002
    Location
    sayre, pa
    Posts
    195
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    alec,
    you wrote:
    &gt;and in practice I used engine oil, 20\50 which &gt;works fine in our temperatures.
    in northern pennsylvania where i live, it has been
    unseasonably cold lately. around 15-20 degrees F.
    &gt;Bear in mind that the underbonnet temperature &gt;will warm everything up.
    i did figure that the underbonnet temps would help, but after a hour drive, i put my hand on the dashpots to check, and they were ice cold.
    maybe the car is just running cold. maybe thermostat change or perhaps i should partially cover the oil cooler.
    wish i were in the u.k., because the coldest i've
    ever experienced it on my many trips was when i was in york. it was in february and very cold.
    i was sightseeing near monks bar and the temp was around 38F. not as cold as here though. can i also do a winter adjustment for the mixture for cold weather?
    emanuel
    maybe it was a bit colder than 38F and all the sam smith oatmeal stout that i had ingested was keeping me warm. (i had to visit tadcaster).
    [img]graemlins/cheers.gif[/img]
  12. #12
    Jedi Knight MGTF1250Dave's Avatar
    Join Date
    Apr 2002
    Location
    Kapolei, HI
    Posts
    1,312
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    Aloha All,
    Happy New Year! This is an excellent discussion.
    In my opinion, the mixture adjustment is probably the last thing to check. The spring pressure on the mixture adjustment nut will probably not move without your help. Most carburetor problems I've experienced with your symptons are things like the connection between carbs is slipping so that the butterfly plates are not aligned (one closed and the other partly open), clogged inlet filter to the float bowl, and sticking float bowl valve. Ignition problems would also be a probable cause of these problems.
    As Alec mentioned periodic cleaning the the dash pot and throat is important to keep it moving freely. The internal passages for air movement also need to be cleaned. These are the holes exposed when the dashpot cover and filters are removed. Pipe cleaners dipped in carb cleaner or a spray can with the extended tube work well for this. A vacuum above the dashpot is caused by air flow through the carburetor which helps it rise as you accelerate. I have also seen the air filter gasket installed upside down blocking the air passages.
    Regarding the oil to use in your SU carburetor, I think you should use the same grade you use in the engine for your climate. It is important keep the oil level about 3/4 inch below the top of the dash pot tube. This allows for the damper mechanism attached to the nut. The top of the tube is about an inch below the top of the bore in the dash pot cover. I have found that a plastic carpenter glue applicator (looks like a plastic hypodermic needle) is good for filling and removing excess oil. Over filling will result in the excess oil getting all over the inside of your carburator.
    Safety Fast,
    Dave
  13. #13
    Join Date
    Mar 2002
    Location
    sayre, pa
    Posts
    195
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    happy new year to all;
    thanks dave,
    when i did the winter oil change in november,
    i used castrol 10w30. seems a better choice than castrol 20w50 for our cold winters here.
    as soon as i get a fair weather day ( so my fingers wont freeze), i'll clean the carbs and do the "final" adjustments.
    maybe the dashpot oil could be changed for the winter, and back to 20w50 for the spring and summer.
  14. #14
    Join Date
    Dec 2002
    Location
    indianapolis
    Posts
    135
    Thanks Thanks Given
    Thanked in
    Re: SU hs4 carbs
    I have always used a light oil like 3 in 1 never have I heard of ppl using 20-50 until I read it here
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
