Fuel gauge calibration procedure
Jerry
It is a very delicate instrument inside and the fine wires will break with much movement. It is adjustable but my experience is leave it alone. There are two small nuts that can move in a slot on the back of the gauge. This is the adjustment. I don't remember which way to move them.
Keoke
Another option is:
Send it in to Nisonger and have it calibrated.
steveg
I’d like to calibrate the fuel gauge on my BJ8. A full tank shows over full, and the tank is empty at 1/4 tank. Does anyone have, or know of, a good procedure?
thanks
Steve
If the gauge shows 1/4 tank when empty, this can be because the sender float arm is pointed to the rear. If that's the case, the arm hangs up on the side of the well and will show 1/4 tank when completely empty. If necessary rotate the sender so the arm points forward.
S
SteveHall64Healey
Thanks- I know about Nisonger, but am not keen to send it there. I believe that if I give it to any tech they would need resistance readings from the sender at full and empty positions.
S
SteveHall64Healey
Thanks - I replaced the sender about 5 years ago and I can’t remember which way I installed it. I vaguely recall pointing the float to the rear. Thanks for the tip!
I am compiling my winter projects at the moment and will check which way it points when the car comes off the road.
I’ve generally wintered the car with a full tank of gas with fuel stabilizer. Any recommendations re this?
steveg
BJ8Healeys
thanks
Steve
I just did this for my BJ8 after I discovered that the float had been rubbing/binding on a baffle inside the Moss replacement tank, making the gauge erratic. Please contact me at sbyers@ec.rr.com and I'll detail the procedure for calibrating the gauge. As others have noted, you have to be very careful not to loosen the adjusting nuts too much, or you can spin the post when you re-tighten them and break the coil wire. That will permanently disable the gauge until the wire is replaced by a professional.
Basically, you remove the green/black "T" wire from the gauge and measure the resistance between the wire and ground with the tank full and empty. Using the resistance values, you build a test set with resistors. When the gauge is connected to a 12 Volt source, the test set resistances for FULL, HALF, and EMPTY are used to adjust the position of the gauge needle for the correct reading. It's a bit of trial and error because the gauge FULL and EMPTY coils pull against each other to position the needle. The adjusting nuts are loosened just enough so that moving the posts in their slots affect the needle position. Better for them to be difficult to move than too easy.
twas_brillig
For any vehicle that I'll store over the winter, I'll try to run the tank low and use no-ethanol premium for the last couple of fills, irrespective of the stuff that it burns normally. Add the fuel stabilizer and make sure that it's mixed well enough and the vehicle is run long enough to get the stabilized fuel through the system. I do a bit of digging each fall to see which of the local gas stations offer non-ethanol premium and go there. Mr. Turney has a great point regards shutting down the fuel pump - I'd never thought of that - could you pop a fuse? I think that the engine might continue to run with the battery swicth turned off, but I don't know enough about the function of the battery in damping out electrical surprises.
We've had a bit more than 10 inches of snow in the last week or so, but it's supposed to get seasonal next week (low 50s; above seasonal!) and I haven't 'winterized' the law mower yet. Figure I'll empty the gas tank, run the engine 'til it stops, change the oil, and spray the heck out of the interior of the gas tank with WD-40. Later, Doug
John Turney
In a stock installation, the fuel pump isn't fused. It's one of the white wires on the feed side (A3) of the 35A fuse. The other white wires go to the overdrive.
I have a dual-sided pump with switches for each side.
S
SteveHall64Healey
I finally got around to this job this morning, and the electrical connection is facing the rear of the car. As well, upon removal of the cover plate housing the rheostat, the gauge shows full with the moving contact pointing forward. The sender must have been installed (by me :-() ) facing the rear. A new set of gaskets just arrived so I will reverse it and test it when driving season arrives here.
thanks
Steve
S
SteveHall64Healey
I have reversed the orientation so that the float points forward. I the tried Viton gasket set from Moss which gave me more confidence in the seal as opposed to the cork gaskets they replaced.
Once installed, I pushed the rheostat forward and backward and got an Empty indication on the gauge with the float bottoming out in the tank and Full indication with the float at maximum height. Should be good for driving season starting in April...
thanks for the input everyone,
Steve
Goldie
Unless it has been modified there is a wire from the cut off switch in the trunk that will short out the coil. At least it is on the BJ8 that I have. I don't know about earlier cars.
martx-5 TR2/3/3A TR3 Fuel Gauge Calibration Triumph 13
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
Rut Bugeye fuel gauge Spridgets 14
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
