Spin-On Oil Filter Removal [BJ7]
twas_brillig
It seemed to take a lot of struggling to get my oil filter off this afternoon for the pre-winter oil change.
I tried using two strap wrenches (one with a rubberish strap about 1/2" wide, a second with a wider/thicker strap) as well as a chain wrench. The filter was about 4 5/8" long, which did not leave room for my "cup" style end-grip filter tool. I've got a metal band style oil filter wrench buried in the garage somewhere, but couldn't find it. I also tried a long chisel and hammer, but couldn't get a good angle (yes, I was, indeed, trying to turn the thing in the proper direction for removal). There wasn't enough room to really be able to turn the filter with the bulk of the chain wrench handle nor with the larger strap wrench; the smaller strap wrench could be turned a bit, but getting a grip with it was difficult.
Persistence with the smaller strap wrench deformed the filter somewhat; not sure if that helped the grip, or if keeping the strap closer to the base where it was structurally more sound was the best approach. The new filter is 3 1/2" long (I'd prefer the longer, with the idea of having more filter medium, and I'll put a magnet on the end of it, just because). I did spray brake cleaner on the filter surface to try to clean off some of the oil. Next time I'll do a better job of wiping it clean with either solvent or brake clean. I was also thinking of slipping a series of rubber bands onto the filter as well for the wrench to hopefully get a better grip on it.
Thanks, Doug
steveg
.... Next time I'll do a better job of wiping it clean with either solvent or brake clean....
Thanks, Doug
If this is the gasket you're referring to, it should be coated with a light coat of oil for installation. I like to take a sharpie and write numbers 1 - 4 counter clockwise in 1/4ths around the periphery of the end. Tighten the filter by hand until contact is made, then tighten 3/4 of a turn. The numbers will aid in this.
All I ever need is a band wrench for undoing.
roscoe
I have been known, on occasion, to drive a long phillips head screwdriver clean through an oil filter and used it to twist off a sticky bugger.
It is certainly not the cleanest way to do it and I suggest you look again for your band clamp style wrench before you resort to this sort of violence. You might try oil filter pliers as the attached photo shows. I have used these for years as even if you start to crush the filter housing they are like channel locks and you just notch them down and go again.
T
twas_brillig
Yup, followed the instructions as always and poured a wee bit of oil into the filter to have the clean stuff to spread over the gasket.
Steveg: i gosh danged never thought of the sharpie labelling approach. I normally just look at the labelling, and eyeball in a 3/4 turn from that. Figure I'll try the 1/4, etc., labelling the next time!
Bob_Spidell
Some aircraft engine manufacturers recommended/spec'd this stuff for aircraft filter gaskets:
https://www.skygeek.com/dow-corning...0HBzuaonzgo_4DrVuZxYUp_4Fuf4G7AYaApw5EALw_wcB
I use it if it's handy, clean oil in a pinch. Also a great dielectric for our prehistoric wiring systems (the same barrel connectors were used on my dad's Model As). If used in the connectors, it helps inhibit corrosion, which I believe to be at least partially responsible for Lucas gremlins. I bought a tube about 30 years ago and still have 90% left.
steveg
Bob - I bought some Dow Corning silicone grease - it looks to be the same as far-cheaper Dialectric Grease, such as that from Permatex.
Bob_Spidell
Yeah, I've used other brands of dielectric grease with good results as well (CRC brand IIRC; I've had good results with their other products too). I do think the Dow stuff is just a bit thicker--and possibly more persistent--because it's in a tube and the other brands have to be pushed out of an aerosol can (and there weren't as many alternatives 30+ years ago). I bought the tube of Dow--it was quite expensive; over $20 for an 8oz tube--because it was called-out by one of the engine manufacturers, we were doing a lot of our own maintenance on our planes and I didn't want to take any chances. I think silicone-based lubricants and sealants are pretty good across-the-board (the silicone lubricants are supposed to dry and leave a film; excellent for speedos, tachs and their cables). The Dow stuff didn't change its consistency over all these years but aerosols sometimes go flat before you can use all of it--looking at you, Kroil--which is pretty annoying.
I'm kind of a wonk on this stuff; I have a background in chemistry and I like to experiment and see what works best in different applications (my dad looked askance at me more than once). Aviation Form-A-Gasket is the go-to for paper gaskets, esp. since it's less likely to form a glob and fall off (there's a video on the 'net with a guy emphasizing this aspect). They say it remains 'tacky,' but it seems to me it forms a glaze and is easier to remove treated gaskets than some other products. 3M 'Upholstery Glue'--aka 'Yellow Snot'--is best for gluing boot seals, and it comes in black (which is a couple bucks more than the yellow-go figure). My BJ8's head has a misshapen valve cover surface, and I had leaks until I started using yellow snot to glue the gasket in place and a thin bead of blue RTV on the mating surface (I can usually reuse a couple times). Sealants and adhesives have come a long way over the years; some body repair is done with a glue, and the aluminium-framed Morgans use a glue to attach the pieces together.
I agree most gaskets can be used 'dry,' but done properly a good sealant just might eliminate one of the spots on the garage floor. The repop gas tank in my BN2 had a poorly-made sender flange, and I tried all the new, 'improved' gaskets with no luck and I finally solved the problem with a couple cork gaskets with a thin film of fuel-resitant Permatex on them (took longer screws, though; don't tell the concours guys ;)).
I'm not quite as picky about tightening oil filters; I have my own torque measurements for such situations: finger-tight, wrist-tight, elbow-tight, shoulder-tight and hips-tight. I tighten my spin-ons to wrist-tight.
Don't get me started on which solvents to use ;)
Edit: I live in California so sometimes have to get 'creative' with chemical solutions. My rule-of-thumb is: "If it's banned in California, it works best;" sometimes, I can 'order in.' The good carb cleaner--the stuff that comes in a gallon can with a dunk basket--was banned years ago and I still haven't found a good substitute (lacquer thinner works, but I can't usually get that either). Mineral spirits, which works good in parts cleaners, is over $25/gallon if you can find it (Dad said he used to get it for $0.25/g back in the day).
T
twas_brillig
Krikey! There's a whole bunch of guys here that are a heck of a lot smarter than this boy! The idea of (1) marking the exterior of the filter at 90 degrees is brilliant; (2) writing date (and mileage?) on the dang think is also brilliant. ANd the essay on sealants brightened my day. Thanks guys! Doug
LarryK
I have always written mileage and dates on all my filters. Have it written on maintenance sheet and in a notebook in the glove box. Can't forget.
Keoke
Yeah BOB :
I live in California too so:
I know what u mean , I see products on line all the time whch can not be shipped to California .
On the other hand :
U can pick them up locally at stores in ca i wonder how they got there--LOL
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
