TR2/3/3A Bonnet popper, or something like that.
GeorgetheTR3
Hi, I am George the TR3,
I have been gone from Briton for so long that I have forgotten my proper English, maybe I never did know it to start with.
The spring loaded button that pops my bonnet up seems to be malfunctioning, at least when the bonnet is unlocked it will not pop enough to get to the safety catch.
I would be grateful if some one could explain an easy way to fix this problem.
You have to take it easy on Royce as he doesn't know know to much proper English either.
Thanks
George the TR3
CJD
It's a very simple mechanism, having only a plunger and a spring. Try oiling the plunger, and take a good look at the spring to make sure it isn't broken. Make sure the flimsy metal frame is not all distorted...and that's about all that can go wrong with it.
GilsTR
If you cannot get it to work I am pretty sure I have some
good condition used ones I would sell.
Advise
Gil. NoCal
GeorgetheTR3
GeorgetheTR3
I did figure out that the spring was / is very weak and I did stretch it out a bit and that helped. but I will probably have to try to find a stiffer spring some day.
Thanks for all your help.
George the TR3
sp53
Over the years on many cars, I have noticed that spring can be so strong that the force actually lifts the hood right there then creates a spot where the hood and apron look like someone has taken a bar and bent the hood up at the latch. I have thought about weakening the spring sometimes. I noticed in someone pictures here someone removed the spring and replaced it with rubber, but cannot remember who.
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
fmichaels Bonnet hinge holes Spridgets 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
C Under boot and under bonnet paint? Austin Healey 7
D TR2/3/3A bonnet safety catch Triumph 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
W Electrics, fuel system, under bonnet temp. Austin Healey 3
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
anarchy99 Bonnet / hood fit question... Spridgets 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
