How do you secure your door rubber trim?
twas_brillig
The rubber trim/draught excluder that fits onto the body and compresses when the door is shut against has decided not to stay in place. The seal appears to be designed to push onto the body flange, with some sort of female metal component in the seal that grips the body flange. However, ours aren't staying in place, and I would appreciate advice as to how overcome this problem. Thanks, Doug
Keoke
In my experience, the only way to keep them on is to replace them with Martin Macgregor's excellent product , which he sent me a sample of years ago.
steveg
In my experience, the only way to keep them on is to replace them with Martin Macgregor's ones: https://macgregorukcarparts.com/ Otherwise, you'll be trying everything, including weatherstrip glue, to keep them on. Not cheap, but worth the expense. You'll need to call him, he doesn't respond well to emails.
Isn't MacGregor's product the 'Bristleflex' Moss and others sell?
T
twas_brillig
Patrick67BJ8
I have seals that came in my interior kit that also came loose.
What I did was grab a pair of pliers and wrapped tape around the jaws and squeezed the seal so the gap closed up. I then reattached it to the flange and squeezed it again. The seals I received had aluminum instead of steel for gripping the flange. If you squeeze the seal to hard you can take a flat screwdriver to open it up a little.
Michael Oritt
I believe that MM's product has a steel core, which will hold a "set" versus AL in the usual stuff, which will eventually deform (unform?), losing its clamping ability.
HealeyRick
https://www.ahspares.co.uk/austin-h...ittings/draught-excluder-blackcar-set-2.aspx; AH Spares lists "Bristleflex door seals" for 275 pounds ($ 472 Cdn); ordering from the site provided by HealeyRick and recommended by Keoke will cost me $ 99 Cdn for a pair, and they're based in Ontario so shipping will be pretty simple for me. Thanks guys! Doug
I think the price list on his website is old. You may want to check with Martin the current price when you call to order
British_Recovery
Bronze
See the Moss Motors part number 249-795. It is under MGA, but also shows for Austin Healey. These are steel and go into the aluminum clip area. It says you need a dozen per side, but on the Healey you can get by with them on the verticals, since the aluminum sill strip covers the door seal at the bottom. Check out some MGA sites for installation instructions. Should work.
Bob
T Where to buy bolts that secure door latch Triumph 10
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
AngliaGT Are You Secure in your Manhood? MG 3
chicken how do you secure the transmission tunnel down ? Austin Healey 19
T What size bolt to secure handbrake assembly? Spridgets 12
Brosky Does BMIHT have a "secure" site to enter info? Triumph 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 3
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
